On 28/07/2022 at 9:44 AM, DaymoR32 said:
thats just a destroked barra isnt it? 😆
https://torquelinegarage.com.au/nxtgen-built-ford-barra-6cyl-3-6l-destroke-1600-hp/
Turn key package too !
NXTGEN Built FORD BARRA 6CYL 3.6L Destroke 1600+HP
ACL Race Main Bearings
ACL Race Rod Bearings
ARP Head Stud Kit Ford BA
Powerbond Balancer
Diamond Custom Pistons with H13 Tool Steel Pins
Carrillo Billet 2000hp Rods
Supertec Inconel 1mm + Valves
Spool Billet 90mm CRANK
Crow Cams BA 6 cyl Intake cam
Crow Cams BA 6 cyl Exhaust cam
BA Turbo 6 Race spring kit
Payen Conversion set Ford 6cyl DOHC
Payen VRS Ford BA DOHC Turbo
6 Boost Twin cam Falcon T4 Turbo Manifold 60mm
Turbosmart 60mm wastegate
ID2000 Injectors with adapters and plugs
Main studs to suit twin cam with main girdle
Hypertune Intake manifold with fuel rail and 90mm Billet throttle body
GTX5533 Turbo
Turbo Housing
Turbo clamp
Cometic Head gasket to suit BA
Turbo dump and clamp
New high flow oil pump with Billet gears
Induction hardened crankshaft sprocket
Ford DOHC Heavy duty timing chain tensioner
Ford DOHC Chrome moly timing chain guide and M8 flanged nylock
Driver and passenger side T/chain guide Upper T/chain guide
Chrome moly vernier adjustable cam
H/Duty Simplex Roller timing chain
Ford DOHC Water Pump to suit BA up to 2003
Spool Main Girdle ARP MSK Ford BA
Powder coat parts Black
  • Like 1
Powerbond Balancer
GTX5533 Turbo
Turbo Housing
Turbo clamp
That’s not a bad price considering it comes as almost as a turn key package
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
