Have been trying to tackle an issue with my R32 GTR's climate control unit for a while now, and finally got some time to try and work out what's wrong. Basically, when I push the 'mode' button, it doesn't change where air is blowing - nor when I push the windscreen button. The door mode actuator just doesn't seem to move at all. Here is what I have done and found so far, but i'm honestly stuck at this point:
  • I've pulled the mode actuator out and pulled the 'locking' gear off, and re-plugged the unit in - and when attempting to change modes the actuator arm still doesn't spin (however, it can now be spun by hand).
  • When carrying out the diagnosis built into the climate control unit, I get the '31, 32, 34, 35, 36' pattern displayed when in Step 3 - door mode position check. This indicates a connector issue, but the connector is definitely plugged into the actuator.
  • The voltage from the pins on the loom that plugs into the actuator doesn't appear to change when I change modes - I thought they would (for example, I thought it would read different when at 'feet' vs 'windscreen'. The voltage readings I got (going from left to right with the pins at the bottom) were: 0v, 0v, 0v, 0v, 4.7v, 4.7v, 0v, 4.7v, 4.7v, 0v.
Any help or assistance here would be much appreciated.
On 7/17/2022 at 5:55 PM, GTSBoy said:
Mode door actuator failure is very common. Pain in the arse to swap out too.
Possibly a bit of a positive / update. I removed the motor, and manually applied power to it and it spun happily both ways. The contacts themselves all seem to respond when they should when the main trigger wheel contacts the metal inside as well. Regardless, I pulled the motor apart and cleaned all the metal contacts, re-greased them with electrical grease and greased the gears. So it actually looks like the mode door actuator is in good working order.
However I now have no idea where to start looking from an electrical perspective. I'm hoping the central, main climate control unit isn't the culprit - but I believe that will have to be my next check. Just I don't know what I should be expecting it to do.
Edited by Dyzzii
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
