Good morning folks, looking for some help on how to treat my new Endless Brakes.  I recently upgraded my bcnr33's brakes to Endless Racing Mono 6.  All was good until I washed my car and parked it overnight and drove it the next day to work and the brakes felt like the rotors were warped shaking about and the pedal pulsing.  I took a look and found these rust spots on the rotors as shown below.  It looks like where the pad meets the rotors, rust formed overnight.  I spent a week daily driving for 250kms, doing hard braking as often as I can when the opporutnity allowed.  It got better but still the rust spots remain and the pedal pulsing remains.  It's been humid here in Japan so it must've rusted bad overnight.  Anyone have experience with this?  I'll keep pounding on the brakes whenever I can but I feel i've done that enough.  My pads are endless street spec so not too aggressive.
I was thinking about hitting the rust spot with a flex-hone but don't want to do that if I don't have to.
If anyone has any advice, I'd appreciate it.  Thank you!
P.S. The last photo is before the rust occurred just to show off how beautiful the brakes are.
Info on the brakes: https://www.endless-sport.co.jp/products/brake_caliper/index_RacingMONO6.html
Remove pads. Scuff them back on some very flat, slightly rough but not too rough concrete, put them back in and attempt to bed them in again. If that doesn't work, discs off, onto disc lathe and give them a little skim. As well as another scuff of the pads.
Dang, I was hoping just hitting the spot with a flex-hone would work.  That means I gotta go to a shop cause Tokyo living means I'm in a tower with a vending machine parking lot and no place to do that kind of work myself lol.
Thanks for the guidance.  Surprised this happened in the first place.
Gotta be careful with brakes when it comes to washing cars unfortunately. I'm surprised that hard braking didn't clean the rust off though.
It's just strange because I've washed my car 100 times and this never happened before.  The car is parked underground as well so I don't really get what happened.  We did have some pretty serious flooding/rain before the wash and it was humid as heck but still.  I did park it like right after washing though.  I'm also disappointed that this happened since the brakes were ¥¥¥¥¥¥¥¥
It's fixable, just get the rotor and pads scuffed/cleaned off with some sandpaper. Annoying but I wouldn't bother with new pads/rotors just yet.
Edited by joshuaho96
That's the plan.  No way I'm giving up on these new expensive rotors lol.  These are times I wish i had a house with a garage to work on a car.
Thanks man and I gotta get an update from you on your progress.  Next for me is a Nismo intercooler. I'm still hoping for a California plate in the future...
I talked to Nismo and they said I need to go do some more back-to-back high speed hard braking. If that doesn't clear it then I need new rotors and pads which would suck.
I think the advice on some really hard braking to get the brakes stinky hot is good.
The advice to buy new pads and rotors is bad. If getting them hot doesn't work you need to just get a mechanic to skim the discs as said above. I'm pretty confident the rotors are warped, that's why the surface rust isn't getting wiped off straight away.
BTW it is perfectly normal for a brake disc to grown surface rust overnight if it gets wet, it gets wiped off as soon as you use the brakes
Sounds good I'll attempt some hard braking back-to-back from high speeds.  It's actually really hard to do that in tokyo area but i'll find a way lol.
The brakes setup is pretty new, like no more than 8,000 kilo's on them.  I've definitely encountered surface rust from washing the car or rain, but nothing like this.  It was like flooded the same weekend I washed it though and drove through some pretty deep puddle but thought it would have dried out by the time I got home.  I hope the rotors are not warped.  The rust is only where the pad met the rotor overnight.  So when it hits that lifted rusted spot, you can hear it and feel it when braking...
Thanks for the advice.  It sounds salvageable!
Edited by Hella_GTR
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
