Hi,
creating a new topic regarding the ecu. I received an ECU ( MEC-R580D) which i belive is from an R33. I dont know if its from GTST or GT-R. I bought this ecu because i need one in my R32 GT-R, and now im looking for information if they are interchangeble? I read on Nistune that R32 Ecu in R33 need some modifications. The only information i got was that that this ecu i received came from r32 GT-R but seems like something isnt right here.
https://www.sau.com.au/forums/topic/483883-r33-ecu-mec-r580d-on-r32-gtr/
The nissan part number is xxxxx-xxxxx format, if you find that it can probably be checked.
I saw you mention elsewhere it may not be interchangeable due to o2 sensors, I'm not aware of any other difference 32/33 in terms of wiring or functionality, and aftermarket plug ins like Haltech sell a single 32/33 part number which implies it will run fine.
Have you tried it? It should physically plug in and run even if the o2 sensors are different
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
