So I’ve finally manually converted my stagea (r33 gtr box) with an Exedy heavy duty clutch. When up shifting gears there’s a hang and slow rpm drop which doesn’t feel right (it’s not that bothersome) but I’m just curious if this is right.
*For example, starting from 1st gear, I accelerate to about 3200 RPM, gas off and clutch in, shift from 1 to 2. At this point RPM needs to be around 2000 to match. But even after I finished shifting, RPM usually still much higher than 2000, I have to wait a little to let it drop before I let clutch out, or I may hear clunk drive train noise due to sudden torque shock from higher than needed RPM*
I copied the above paragraph from a different forum regarding a completely different platform but that best explains my experience.
I’m currently thinking it could have something to do with the Auto ECU being retained in the conversion or plainly because of the Heavy Duty clutch.
Also, would haltech be able to control this issue as that will be my standalone soon enough.
Edited by SLIXK
https://www.sau.com.au/forums/topic/483893-slow-rpm-drophang/
That's not how a clutch works. It's not a switch. Clutch goes from disengaged to engaged smoothly and takes up speed difference. Throttle applied at the same time to satisfy load change.
If you truly have a long rev hang, have you considered that the auto tranny will mask a lot of problems with things like the idle speed being wrong/too high from the throttle plate being stopped too open or a vacuum leak/IACV problem? The manual makes you have to take care of that, via the first paragraph^.
It won't be the auto ecu causing the issue, and it's not normal. I ran my manual swapped Stagea on the auto ECU for a while before I moved to PowerPC, the reason I moved was to run more boost.
Like GTSBoy said, for revs to stay up (or fall slowly) there has to be some additional air in the system somehow. Even if the ECU is adding too much fuel you need 14x the air to keep the engine running.
Does the same issue happen if you rev it when stationary, out of gear?
Yep hangs longer from 3rd or 4th to neutral and releasing clutch sometimes it stays at a certain RPM like 1200 until the car comes to a complete stop.
This is out of gear and stationary, it was the like this when it was auto too.
Got it, so I would say that is normal returning to about 1500 then something is adding air for a little until it returns normally to 800.  I'd disconnect the IACV and AAC wiring and see if it still happens, might be ECU sending a signal to add air, or might be a faulty air valve if it still happens
I'm curious to see what you find on this. I had this same thing happen in a S13 that I had converted to manual years ago. I replaced the IACV but never got it to behave properly.
I always wondered if the ECU is looking for an "in gear" signal opposed to just being in neutral all the time (signal wise). In the Suby ECUs it would not use the correct mapping until it saw it was in gear. It still ran/drove fine but was never quite 100%.
There is no "in gear" signal. If you correctly wire up the original auto neutral switch input to the manual's neutral switch, the ECU works properly.
Incorrectly (ie, not) wiring the neutral switch is not assumed (by me) to be something that would happen.....because it is so bloody easy to do it right.
Would the neutral switch not being connected cause these symptoms I’ve described?
Will try this a good day, maybe today lol.
I was thinking the auto ECU sees drive/reverse, the neutral/park is only for the starter circuit correct?
No. Absolutely not. The ECU needs to know if the auto trans is trying to stall the engine, which it is, when it is not in N (or P, which is the same thing). The idle control relies on it.
  • 1 month later...
On 7/29/2022 at 4:41 PM, GTSBoy said:
Absolutely. Clutch switch too.
Back onto this thread, how can I check to confirm that the neutral switch and clutch switch is hooked up?? Maybe this problem is also linked to my new throttle body problems ?
Edited by SLIXK
  • 6 months later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
