Hi all, thanks for letting me join group. Some help here would he much appreciated. My son bought he's 1st R31 and we have no Speedo working. I have attached Pics if what we discovered yesterday. It's a conversation to manual.
Cheers Matt
https://www.sau.com.au/forums/topic/483900-speedo-not-working-1990-r31/
Welcome to the forums Matt, and well done to your son for making an excellent choice in 1st car.
I am not familiar with R31 setups, but R32 used a mechanical speedo drive from the gearbox to the dash and I suspect R31 might as well. Is there another connection further back on the gearbox on the passenger side? Of course this may never have been done properly when the manual swap was done.
Here's an RP71C #2 (photo taken from this very site) showing an electronic speed sender.
http://i68.photobucket.com/albums/i30/0t1/more/IMG_0296.jpg
I'm not at all sure what that 3pin connector is all about - unless it is the wiring for the reverse and neutral switches brought together. It's certainly not the usual connector for the speed sensor.
Anyway - I'm pretty sure that the R31a used a mechanical speedo drive, and this gearbox, being an R33 turbo box (the best thing to have, by the way) usually has an electronic speed sender, as in the image above. So - you cannot make it work without building a mechanical speedo drive. You will need the speedo drive from a Navara from the same period to do this. I think you have to use the gear from your electronic drive to get the right ratio (Navara being different). There are howtos on here and elsewhere on the net, although I've never actually seen one as I didn't have to do mine - my bro'-in-law built the drive for me.
Cheers mate. Will check to see if cable is actually in the back of the dash tonight and we'll take it from there. Appreciate your feedback a lot.
Hi Matt, I have a RP71C#2 gearbox in my car and it is the twin synchro RB20det gearbox from the r32 Skyline, my car uses a mechanical drive speedo which I recently replaced the speedo pinion drive as it disintegrated and jammed up and would not let me select 5th gear.
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
