As in the title is it possible to import HR33 GTS RB20E RWD and ENR33 GTS4 RB25DE AWD 4 doors?
Last i recall we couldn't import due to power to weight ratios being too low for aus to accept compliance but thats just whispers in the wind from 10 yrs ago so i dunno.
Cheers if anyone knows :)
I have not been through the process under the new rules, but it looks like any car > 25 years should be possible
https://www.infrastructure.gov.au/department/media/news/how-import-your-older-vehicle-25-years-or-older
However, not that if they are not on the RAV you have to apply and get them approved, this may not be simple (or possible), so best get advice from someone who has been through it
  • Like 1
Yes we can import any passenger car over 25 years old. new law came into effect early 2019. replaced the old pre-1989 rule.
However now the only hurdle is car insurance. i made several inquries for a Nissan R'Nessa GT Turbo and they never heard of the car model. so i doubt you'll be able to insure HR/ENR33 RB20E.
Have you imported one or were you considering? First time I hear of them. Makes me think of a bit more quirky Stagea. Apparently SR20DET though on the same curb weight.
Caldina without the Toyota reliability? No thanks. No thanks to almost any post-Renault Nissan anyway.
I was considering getting one to use as a daily but couldn't find an insurer. yeah i've always wanted one but wasn't eligible under SEVS. SR20DET wagon automatic 90s nissan styling.
  • Sad 1
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
