R33 GT-R installation of bumper mesh
I promise there will be no chance of replacing the rad support.... It is barely twisted and it's way more likely to just be driven around with a slightly twisty support. As long as the headlight can be bolted in there then no harm no foul lol. The reo may need to be un-bent a little but truth be told if it all somewhat lines up and is hidden when the car is assembled the level of f**ks will be 0.0Â
this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road  -
Some of the stuff the PDR guys in the states pull is amazing too. Instead of drilling a hole. They crank some insane tension into it. I actually DIY built a pulling bar myself that I used to pull the Subarus front end out with. About an hour's work, a bit of 30mm *3mm shs, and a piece of 5mm thick plate. Worked great! Â But I vote replace it with a GTR rad support. And not going to lie, I'll laugh if a GTR rad support doesn't fit a GTt...
Sorry, that was with regards to the rather pretzeled corner of the reo bar. It's in such a state over the years that drilling a hole is probably preferable to bothering to unbolt the thingÂ
No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
