Recently done a bunch of upgrades to my 32 sedan and having some issues with the AFR. Was standard rb20det with just ISR exhaust, FMIC, and an op6 turbo until the seals decided they were done on the turbo.
So I got a new gt2860rs, nistune (installed and tuned by rs enthalpy), deatschwerks 550’s, aeromotive fpr set at 45psi, walbro 255 , z32 maf, and aem UEGO.
Upon start up my wideband reads 14.7 but within 5-10 seconds will peg out to - - - meaning lean. I tried hooking the white wire (signal output) from AEM to the white wire on the o2 harness but it didn’t make a difference? I’ve also tried putting the sensor in the upstream (3” from hot side) and downstream (36” from hot side) positions with no luck on either?
If it’s in the upstream position and under a lot of throttle it will richen SOME (16-17) but shouldn’t it be sitting around 13-15 at idle??? Have not tried driving the car yet to put it under load…
Am I missing something? Seems I’ve misplaced my old o2 sensor but should I just get another and resort back to narrowband to see if that fixes the AFR?
https://www.sau.com.au/forums/topic/483921-nistune-wideband-help/
Have you set MAF to z32?
set injector size?
When I have used nistune, wideband is connected to the laptop via USB.
If can't connect to laptop put the sensor in the dump pipe bung and just adjust it reading off the guage.
@Dose Pipe Sutututu has more Nistune experience than me
  • Like 1
Depends on your AEM gauge, older ones has the option to simulate a 0-1V output which could be used to send back to your ECU for narrowband O2 feedback.
However needs to be noted, if the tune had the O2 feedback disabled wiring it back will do absolutely nothing.
If your car is pegging that lean there may be another issue. You'll need to plug up and monitor the AFM voltage and TP Load and see if it's doing something weird and tracing into parts of a map that has been untuned.
I highly would recommend you bring it back to your tuner.
set injector size?
I sent Martin the list of parts I just mentioned for him to set the base tune parameters around that, including the wideband in place of the o2.
will need to find someone with a laptop and consult cable to check and see if that’s been done correctly.
I purchased the UEGO at the end of last year. The manual said white wire was 0-5v. I know the standard signal is >1v for these cars.
will have to find someone with a laptop and consult cable to check into the tune. Appreciate your quick replies.
also it may be worth mentioning I have a standard fuel rail, one that came with a regulator on both sides. I replaced the one at the beginning of the rail with one of those ISR pass thru’s but left the one at the exit. Could this also be causing an issue or it’s unlikely to make a difference?
Edited by Axt3365
On 8/8/2022 at 6:03 AM, GTSBoy said:
There's your problem. The stocker is not a reg, it is a pulsation dampener.
Meaning it won’t let enough fuel pass through the rail despite what pressure is on feed side?
just ordered another to replace the dampener and see if that makes a difference. Thanks!
Edited by Axt3365
Another thing that comes to mind, have you given the fuel pump full voltage and bypassed the stupid factory drop resistor?
Easiest way to just connect the pump's -ve from the fuel tank lid direct to chassis to bypass the FPCM/drop resistor.
Is your fuel pressure respecting the requested pressure + manifold pressure/vacuum?
I have not bypassed it, just connected back as factory fuel pump was. I’ll try that this evening.
the gauge on FPR is holding steady @ 45psi
Edited by Axt3365
RBs are tough little things, to rule out any air leaks through the hot side, I suggest just take the car for a gentle drive and gentle load it up till close to 100kPA aka 0 psi for you Muricansssssss.
See if your AFR readings are somewhat richer than stoich.
I nearly feel you may have an small manifold leak somewhere OR a dump pipe leak somewhere that's introducing additional air into your exhaust stream thus the lean reading.
Anyhow, easiest way to diagnose all this is on a dyno.
  • Like 1
I appreciate all your help and advice. I’ll finish tying up my loose ends, and get the car rolling around the neighborhood in the next few days and report back!
  • 2 months later...
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
