So I got the engine cranked over, got good oil pressure and no more leaks! I need to work out the NSP software a bit more, as the fuel pump isn’t priming nor does the starter motor kick in when I press the programmed button on the keypad. However when I change the active state from high to low then they go (which is how I primed it). It’s not a wiring issue, as I can set the individual keypad state change when pressed, so will be a setting somewhere..
The engine bay is pretty much complete now before the fab work
I dusted off the old coil/valley cover and trimmed off the old stand-offs for the igniter. My fabricator will fill the holes and tidy up, including smoothing out the cam covers (there’s a slight indent on the intake side one on the 20det covers). Once that’s done, I’ll get them painted.
One thing I have been thinking about is the intake side and whether I source a factory air box and snorkel for that OEM+ look I’m going for... I’m only expecting 300ish KW’s, so don’t think it will be a restriction? Thoughts?
  • Like 2
So I have spent a couple of hours trying to work out why the car wouldn’t start when I pressed the keypad button, even called haltech support (I wasn’t with car but had my tune, for them to see).
Anyway, I just realised that my keypad is inverted and I haven’t taken that into account when I programmed the buttons. Real face palm moment. Engine cranks no worries haha.
  • Haha 3
hahaha glad it was a simple fix. but that is funny.
great work on the car, the setup is looking good.
you could modify the stock airbox to have larger inlet and put a pod filter in it if you wanted to.
Thanks! Yeah I test fit it last night and I think I can modify the air box to install an extra air inlet beneath the guard with a pod on it. I will get the pipe work made up to fit the stock air box, if it doesn’t work out I’ll just get a custom one made. I think the stock air box fits the oem+/restomod vibe better..
I have been looking into Varex mufflers and the GFB electronic BOV. I think it would be cool to have a button for different drive modes that control boost, pedal sensitivity, exhaust noise, throttle blip, BOV noise and maybe even like a twin edfc controller etc.. that can maybe be the next stage of mods, as I just want to get it done to drive it..
  • Like 1
1 hour ago, WR33KD said:
I have a plasma man intake box for the 33, replaces the stock air box
I have seen them, looks nice! If I went that way I would not want the cutout for the old charcoal canister though..
So It’s been a while, between work and home life with 5 month old twins and a 6 year old not really much progress…
however I managed to track down a stock air box and snorkel in line with the OEM+ theme:
I know it will be a restriction in its current form, however I’m looking to modify it with an additional 3” air intake through the bottom of the box and to go through the 2nd hole for the old SMIC. When it does eventually get on the dyno, we’ll test with and without, to see if it’s still a restriction. If it is, then no real loss and in the bin it goes..
A couple of annoying issues fixed:
I noticed a tiny water leak from the plenum, which I traced back to one of the temp sensor ports that I plugged. I noticed it didn’t have any thread sealant… added some and it seems to be fine.
I noticed my IC7 dash would intermittently switch off when cranking… A bit of research shows it’s the dumb way (IMO) how Haltech ground their CAN network in the pre-terminated harnesses. Essentially as soon as you add a wideband unit, then you need to ground via battery ground but yet it’s pre-wired to signal ground. I could have just read the wiring diagram for the wideband unit I guess… but it could also have been wired the correct way first..
Edited by R3N3
  • Like 2
Great progress today!
Got the car started, purred to life first go! Even with 18 month old fuel. It’s running as NA at the moment though, as there’s no cooler piping yet. There was also no fires or more leaks, which is always nice... There was a bit of smoke from the turbo and down pipe but this was just the oils etc. burning off. Thanks @Dose Pipe Sutututu for the trigger settings and other haltech tips!
I got the coolant up to about 70 degrees, which had opened the thermostat fully (using a nismo low temp) and initial thoughts on the thermo fan are positive, as I was playing round with the duty cycles and even at 30% it reduced the coolant temp quickly.
there was a couple of times the idle would hunt, so need to look at the settings a bit better there..
  • Like 1
Car was picked up today and taken to the workshop. List of work being done:
Aluminium intercooler piping 2.5” hot side & 3” cold side. Weld on Turbosmart raceport BOV and IAT sensor.
Full 3.5” SS exhaust, with v-band joins. It will be getting one decent resonator in the centre and a custom NZ made muffler (AdrenalinR) for some nice and subdued RB noises. I will be going two 3” tips for that OEM+ look. I don’t need a cat for it to be legal, so will not be running one (we’re less progressive with emission laws here).
Custom air box. For now I am parking the factory air box until I sort the additional intake for it, as it will just be a restriction.
Welding up the valley cover so it’s nice and Smooth and has no holes. And the indent in the intake side cam cover will also be filled with weld.
Tune is booked for early April.
  • Like 3
So i have been on the hunt for some nice 'genuine' wheels lately, scouring trademe (our version of ebay) and marketplace. and i narrowed it down to BBS LM's, Enkei RPF1 or Work s1 or m1. Personally, i generally think there is no place for an even number of spokes on a wheel, however one of the few exceptions to this rule is the RPF1. basically, finding good second hand wheels at a reasonable price is nearly impossible and im not confident in my abilities to pick the fakes from the real ones..
so to cut to the chase, i just pulled the trigger on some brand new S1 3-piece wheels:
Front = 18x9 +18
Rear = 18x9.5 + 11
Im currently running 17x9 +15 F and 17x10 +15 R, so these should fit nearly the same as my current wheels.
the wheels are gloss black centers with polished lips and polished assembly bolts:
Normally the lead time is around 20 weeks from Work Wheels, however, the supplier had a spare set in his next shipment, due beginning of April.
  • Like 2
32 minutes ago, Murray_Calavera said:
With the 17" wheel setup, what tyres and size were you running and what was needed to get them to fit? Did they rub anywhere?
I was running a 255/40 on the rear and a 235/40 on the front. Tyres were a Falken FK452 tyre. All I did was roll the guards to get them to fit. I didn’t have aftermarket camber arms, so I think there was about -1.5 deg of camber due to the lowering. Only occasionally would the tyre scrub.
  • Like 1
I found out I was not successful in the ballot for a new GR Corolla today :( there’s another 100 vehicles arriving later in the year, so will give it another go then..
On the skyline front, car is still at the fabricator, however I have purchased a new wireless CarPlay head unit (Sony XAV-AX6000), new PRP HICAS lock bar (needed new one as I need to re-certify my car and the old one is no longer accepted) and I am actively looking for a Nismo 1.5way LSD. I’m in Sydney for work next week, so will see if I can maybe pick one up there..
Oh wow, I thought they weren't going to sell them in AU and NZ. I more or less stopped following the news on them because of it. This changes... not really anything for me... but makes me want to read up on some more impressions of it. Fingers crossed it'll work out for you.
Have you had a chance to drive one? Or the GR Yaris?
Looking forward to see what it will look like in person. At least on the photos the GR Corolla seems to look just like a Corolla. Except for the triple tail pipes. The GR Yaris compared to base model is quite different and has a lot of road presence I find. This might be a proper sleeper I guess.
I know there’s only 250 units coming to NZ, not sure about AUS.. I actually haven’t driven the GR Yaris or the GR Corolla but assume it would be fun.. you? Toyota NZ are also making people sign contracts so they can’t sell to anyone other than Toyota for 12 months. I believe they are also doing this with landcruisers
My wife was actually not happy, as I was going to get the Corolla as my work car and replace my kodiaq. She can’t drive manual, so would be confined to her kia carnival haha.
  • Haha 1
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
