So I got the head unit all installed this weekend:
Wireless CarPlay is the goods! I just need to wire up the reversing camera and the reverse input. I tidied
All weekend I have tried calibrating both the fuel level sender (in the IC7) and the vehicle speed (through the ECU), with no luck. The vehicle speed issue means I can’t test out the cruise control…
  • Like 4
13 minutes ago, Looney_Head said:
heads up for the cert, when i did mine, i had to have two loops due to how and where the center hanger was.
great work on the car, looking and sounding good. and solid power :)
Thanks!
Funny that. My cert guy was the one who said I needed 1… let’s see what happens.
  • Like 1
If he said you only need 1, you should be OK. But officially it's 2 on a 2 piece driveshaft.
There was some talk they were going to relax the rule a bit. Maybe it's starting to happen.
I certed my 30 conversion before the hoop rules came in, but want to do brakes which will trigger a re-cert. I'm hoping to squeak through
  • Like 1
Try this setting, the out of the box Haltech value is much higher and reads weird
Also if you're running the latest version of the firmware, there's a known bug with VSS doing a few thousand km/h lol
Yes, I did have the latest firmware, so I think that’s the issue! Also, no more haltech forum?? I joined that FB page too..
the fuel sensor issue on the IC7 also seems to be firmware related. For some reason the software isn’t updating it with the latest firmware…
27 minutes ago, soviet_merlin said:
What the heck? Did they completely axe the forums and all content? Intentionally? This blows my mind. If it was intentional it seems so incredibly misguided I can't even comprehend it.
It appears so!! I solved a lot of problems just searching on there..
On 23/5/2023 at 12:05 PM, Dose Pipe Sutututu said:
Hopefully easy fix!
And yeah, a bit sad they removed the forum. Facebook is a bit shit, same questions get asked every week.
Fixed the speedo issue. Funnily enough, my settings were around 5221 pulses/km and I think that was calibrated at 30km/hr. Verified the speed with a shitty app that lagged heaps, so probably wrong still haha but at least I’m not doing Mach 2 anymore.
played with the idle a bit, as the tuner had it set at 900. The DBW makes this super easy and super stable! I backed it down to about 750/800rpm and it’s rock solid!
just need to figure out the fuel gauge next!
  • Like 2
As part of my cert tomorrow, I had to update the HICAS lock bar, as there is some picky rules re. bars with welds. This is why I bought the PRP bar, it’s billet with no welds..
The bar itself is great but I feel there has been little thought on the actual application. I had to cut 10mm off the thread on the arms to get the toe adjustment anywhere near right. They say they are bringing out new arms for it but who knows Wel hen that’s happening.. I should have gone with a gktech full delete kit.
  • Like 1
53 minutes ago, WR33KD said:
You should have just run a non hicas r200 frame and arms and knuckles to suit, way less stress and it’s a way cleaner look under the back
Yeah, I will investigate this.
also, I will be getting a flex fuel sensor, so I will be getting me some of that ethanol you linked! Cheers!
  • Like 2
So the car failed the cert, however on really minor stuff:
  • Exhaust is 1.9 decibels too loud (was 91.9db at 3200rpm and needs to be 90)- im just going to put a restriction in the exhaust to get a pass. i may quit down the exhaust long term, just want to get a good feel for it first..
  • I need to put a cover over the fuel top hat (factory one doesn't fit because of FPG top hat). ill just have to modify the factory one to suit.
  • no airbag diagnostic light on the dash (as i now have the IC-7). i wish the IC-7 had more customisation here with different logos etc. but nope. I have ordered a little airbag logo light that i will install on the dash.
I should have this remedied next week and finally be legally back on the road.
Edited by R3N3
  • Like 2
  • 1 month later...
22 minutes ago, Dose Pipe Sutututu said:
Congrats!
How does it feel on the street?
Really good! The turbo whistle is much louder than I thought it would be. It’s so much rougher than I remember lol. Spending too much time driving the smooth Skoda with heated steering wheel and seats, 360deg camera etc..
I just need to do a road tune to get it 100% perfect
  • Like 1
20 minutes ago, Dose Pipe Sutututu said:
I totally get this, with the MK2 Tiguan.
Get into the R33 and it feels like a croc of shit.
Best thing is the wireless CarPlay head unit! I just need to get an amp and speakers.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
