6 minutes ago, R3N3 said:
I didn’t see that. I found a crowd in aus called RB factory that make R33 specific ones
Hah, and I didn't see yours when I was looking for some. Looks like it's a similar idea / design.
It's one reason why I like reading the build threads here. Like for example the custom ashtray keypad mount you mentioned a few posts earlier went straight on the maybe-one-day-santa-list :D
Yeah, to be fair I stole the idea from @Dose Pipe Sutututu . The mount is great, it even uses the ashtray spring clips to hold it in place. I’ll get him to update his website to include it (if he hasn’t already).
I like yours more though, the one I have is a bit rough around the edges and is a friction fit. I had to use foam tape to stop it flying out on hard acceleration.
The one I have has no provision to easily swap over the spring clips from the ashtray.
19 hours ago, R3N3 said:
No worries, how did you choose to adapt dbw?
i'm still VH45 TB for now. i need to fix my miss fire that has developed since fixing replacing my head gasket and changing coils :(
So while planning the loom fix for the A/C relay, I thought why not just ditch the relay and power from PDM? It will definitely simplify things and free up an output on the haltech.
my basic understanding of the A/C system (based on vehicle wiring diagrams):
- A/C controller sends signal to ecu (pin 46)
- ecu provides 12v out to engine bay (pin 9)
- 12v from ecu goes via the pressure switch (canister near radiator)?
- pressure switch then enables A/C and auxiliary fan relays, turning on compressor and fan when water temp gets hot?
Based on this, just simply running an 8A output to compressor would seem to bypass pressure switch, witch doesn’t seem like a good idea? I’d need to wire the pressure switch with 12v and an AVI to create a rule to then switch compressor on?
Edited by R3N3
This is the r32 wiring (I don't have the r33 one handy), but likely the same or similar.
The diagram is not clear that ECU pin 9 to pressure switch is +, but it later states that.
So, to move AC to a PDM control just output the AC signal on pin 9 as standard, and run your PDM output to the AC relay, the you keep the pressure switch input to stop it trying to overfill.
Alternatively it you really don't want the relay you need to connect the pressure switch to ground on one side and a spare DPI on the other. Then connect the PDM output to the compressor directly. Then setup the ECU to use that DPI as a condition to turn on the AC output.
Keep in mind that is only half the AC control. The other half depends on what the climate control is set at.
  • Like 1
This is what I was thinking, although may be out of my depth wiring/programming wise… I will add the necessary wires into my loom (and not bin the relays just yet) and then give it a go. At least it’s pretty simple to go back to the factory method.
here is a snip from the R33 wiring diagram:
this was a screenshot from the iPhone, so quality may not be the best..
Edited by R3N3
  • 3 weeks later...
Wiring loom is now complete, with ECU turning on and no fires or fried electronics to be seen… The IC-7 is also working nicely with the indicators, screen dimming with lights on, park brake etc. all working nicely. All the factory vehicle functions that were patched in work nicely too!
I have upgraded the ECU to the latest NSP software, started with a haltech R33 base map and am in the process of allocating all I/O’s and checking sensor tables etc.
on its way from Brisbane is the FPG fan shroud and fitting kit, where I will run the 3000cfm SPAL fan via the PDM, which will replace the factory clutch fan.
now just counting down for all the fab work then the tune..
  • Like 2
So, been playing around setting all the I/O’s and the only one issue I have is the throttle body will not calibrate.. it’s throwing a ‘P2109’ fault code.. will touch base with haltech to try sort.
other than that, everything is good! All that’s needed now is to re-make the turbo oil and water lines (not happy with first attempt). Then I will double check all bolts/fittings before putting fluids in.
a couple of pics of the finished interior:
  • Like 3
double, triple check your DBW TB wiring, there are some models the pins are reversed for whatever reason, also do the same on the pedal.
Can you get a screen of all your voltages?
Ok. The pedal calibrates fine though?
below is a screen pic of when the throttle calibration is running:0C0EA587-1C50-4121-AD30-6F4C7A79921B.thumb.jpeg.7f6f14e77fcc6ba6373a0af286193d01.jpeg
its applying duty cycle (and it’s audible) but the throttle barely moves (not even to the fully closed position).
to verify the throttle wasn’t stuck, I physically moved it, with the below results:
It shows the TPS itself (middle graph) is working fine? And the top graph is plotting the APP (pedal press was independent to throttle calibration).
thoughts?
Edited by R3N3
thoughts?
Also for shits and giggles I switched the pins for the motor + and - at the ecu connector to see if it made a difference. No bueno.
hmmm
I see that APP1 vs APP2 has difference voltages, they "should" be nearly the same.
Maybe try borrow another pedal from someone or from someone's nan's Nissan X-Trail lolol...
38 minutes ago, Dose Pipe Sutututu said:
hmmm
I thought they are supposed to be offset by approx 50% for fail safe? Would the pedal cause the throttle calibration issues?
I better look at mine running again, I just pulled up old logs and saw the same voltage for APP 1 and 2.
  • Like 1
Ok, I was just reading some googles that said they are offset.. I’m definitely no expert! I’m running a 370z pedal if that makes any difference.. thanks for your help!
I have just unplugged the pedal connector and checked the voltages supplied to both APP circuits with a multimeter. Both are getting 5v, so that rules out any of my dodgy wiring (to those pins anyway).
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
