The car is nearly there, still on track to pick up tomorrow. Super happy with how tucked the exhaust is:
It all is higher than the rails.
intercooler piping will be completed today:
Don’t worry, I will have an airbox. This will be another item that I have taken inspo from @Dose Pipe Sutututu, so will look very similar to his..
  • Like 3
But more importantly, is that a Super Turbo in the background?
  • Like 1
I don’t think so, but I could be very wrong!
the body lines don’t look the same to me..
Edited by R3N3
5 hours ago, Dose Pipe Sutututu said:
wow... look very OEM+
Looking superb!
The airbox cover is real nice, it goes down and seals up against the pipe work too!
Thanks, though I did steel the design from you. I literally gave one of your pics from here to the fabricator…
I have noticed today that the trigger wheel is just touching the sensor, causing a not so nice noise (which made me panic). Anyway, the kit comes with shims, chucked one in and it won’t start… obviously the sensor is now spaced too far from the teeth and can’t pick up a signal for the haltech.
@Dose Pipe Sutututu and/or others with the same trigger kit, is there a setting in the haltech software to adjust the sensitivity, so I can space the sensor out?
Bring up the scope and/or just look at the trigger voltages and crank the car.
Now see what it's registering at, and adjust your trigger arming voltage table so it's a little below the voltage at crank.
I'll send some screen shots tomorrow when I'm at my desk.
  • Like 1
Haha wouldn't say it's stealing, when other Skylines also have similar designs.
Inspired by one another
  • Like 1
This is what you need to adjust, ideally you want the trigger arming voltage to be a touch lower than the actually voltage read at the cranking RPM.
I would setup a screen similar to this, and then cranking the car and see what you need to adjust the trigger arming voltage to be at.
This is from a Haltech article
https://support.haltech.com/portal/en/kb/articles/trigger-arming-voltage
Awesome, thanks!
unfortunately I have misplaced the shims between the workshop and home, so I’ll have to just go with as it is for now for the tune tomorrow. I’ll order more shims and adjust the voltages myself.
I did a final once over tonight. I pulled the injectors for an inspection, as I remember one didn’t go in so smoothly (my error). Turns out I bent the tip slightly. I’m not sure this is a major?
no biggie, as I ordered 2 spares when I purchased (I like to have a spare of most things).
Other than that, car is 100% good to go for tomorrow.
I also purchased and installed the gktech bash plate, as I’ve always hated that the underside of the engine was exposed.
  • Like 2
Tuning went well!
Car made 420hp at 19psi at the hubs. Full boost by around 4000rpm.
Base boost pressure is a nice streetable 10psi with 3 different settings up to 20 (via keypad).
@Dose Pipe Sutututu, the tuner said he barely needed his big fan with the FPG kit, as it could hold it solid at 82deg through the power runs.
  • Like 3
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
