Plan now is to get it 100% road legal. In NZ we have to get the car certified for the mods. This basically involves a thorough inspection, road drive etc. Technically my car was already certified but it was not done with engine mods (just suspension), so things like the dash, keypad and wastegate will be a dead giveaway… we also have to cert the wheel sizes, so by me just going from 17s to 18s would also trigger a re-cert.
  • Like 1
Do they do an emissions test too?
I know if I tried with my car I would need to make it quieter, run smaller wheels, install a 400 cell cat, plumb back the catch can, reinforce the body work for the FMIC piping cut out, etc.
So much harder in NSW, Australia. Other states in Australia are a bit easier.
No, no emissions test and you only trigger the need for a cat converter if you do an engine swap (hence i dont have one). A catch can is a bit of a grey area at the moment, how i read the legislation i have to, but the cert guy says no, so who am i to argue... I also need to install a driveshaft hoop, which has been made and ready to go on.
  • Like 1
28 minutes ago, Duncan said:
There is a driveshaft loop from factory in the middle of the shaft, it also holds the centre bearing to the body.
yeah interested he needs another one? Unless I'm reading this wrong: "I also need to install a driveshaft hoop, which has been made and ready to go on."
Yes, any cert because of a power increase triggers it (a manual swap doesn’t).the driveshaft hoop is for each section of driveshaft, as the R33 has 2 pieces it requires 2. However, as @Duncan pointed out, the rear section (if I remember right) already has one with the hanger bearing, so i only need one for the front section.
  • Like 1
10 minutes ago, Dose Pipe Sutututu said:
interesting rule!
I recall you guys have another odd one where you can run a screamer pipe, provided it goes all the way to the rear of the car and exits next to the rear muffler.
That used to be true. As long as it vented to atmosphere behind the cabin of the vehicle. I think now that all exhaust gas has to go through a muffler also.
  • Like 1
15 minutes ago, Duncan said:
Odd. The standard one is accepted in Australian racing.
You probably just need flat bar between the floor rather than a "hoop" as the tailshaft is above floor level in the tunnel
Nope, needs to be a hoop. Minimum 5mm steel. I’ll take a pic later. But yes, it is odd
Edited by R3N3
  • Like 1
Whoever is coming up with these rules need to relax the glass BBQ lol.
Sure it's for safety but surely for a car making 320kW that's clearly not needed, especially these cars the rear CVs would snap first before the tailshaft even begins to fatigue.
But rules are rules.
Here are the final dyno reports for each boost setting:
wastegate spring (7psi):
ReneNielsenFAD745Wastegatespringpressure.thumb.jpg.42bcd5fe29581981ae4a9ed83f0f144e.jpg
note that gate pressure sees the boost creep up to 12psi.
12 psi:
15psi:
20psi:
Went for a quick drive up and down the street after the tow truck dropped the car off and man it is nice. The sound of the turbo, exhaust, intake and BOV is just so nice! The power feels so linear in how its delivered.
  • Like 4
very nice power band you must be super happy, now for a flex fuel setup. Looking at the boost, and power curve, etc. there's enough headroom for near 400kW at the hubs! Power is still climbing, still room for more boost :D
(don't listen to me, you'll end up making 400kW and then the motor will go bang and you'll have a sads then do something dumb like build a motor and regrets all round)
  • Haha 1
Haha. E85 is not easily accessible here in NZ, as it’s no longer sold at fuel stations (I think nation wide now). However… I have found a supplier who can ship large drums of the BP racing corn juice. I even wired in a connector for a flex sensor in the engine bay. I am just working through the legalities around the storage of the fuel etc.
My limiting factor at the moment for more power will be my clutch. It’s a HD full face organic clutch, which is rated to around 300ish kw and 450Nm torque, which is where I am. I will start to assemble parts for my stage 2 build, which will likely be a RB30, so when it does go bang I have something ready to drop in..
  • Like 2
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
