R3N3 Posted May 21, 2023 Author Share Posted May 21, 2023 So I got the head unit all installed this weekend: Wireless CarPlay is the goods! I just need to wire up the reversing camera and the reverse input. I tidied All weekend I have tried calibrating both the fuel level sender (in the IC7) and the vehicle speed (through the ECU), with no luck. The vehicle speed issue means I can’t test out the cruise control… 4 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979686 Share on other sites More sharing options...
Looney_Head Posted May 22, 2023 Share Posted May 22, 2023 heads up for the cert, when i did mine, i had to have two loops due to how and where the center hanger was. great work on the car, looking and sounding good. and solid power 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979700 Share on other sites More sharing options...
R3N3 Posted May 22, 2023 Author Share Posted May 22, 2023 13 minutes ago, Looney_Head said: heads up for the cert, when i did mine, i had to have two loops due to how and where the center hanger was. great work on the car, looking and sounding good. and solid power Thanks! Funny that. My cert guy was the one who said I needed 1… let’s see what happens. 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979701 Share on other sites More sharing options...
fletch rb30 Posted May 22, 2023 Share Posted May 22, 2023 If he said you only need 1, you should be OK. But officially it's 2 on a 2 piece driveshaft. There was some talk they were going to relax the rule a bit. Maybe it's starting to happen. I certed my 30 conversion before the hoop rules came in, but want to do brakes which will trigger a re-cert. I'm hoping to squeak through 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979703 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 22, 2023 Share Posted May 22, 2023 On 21/05/2023 at 2:22 PM, R3N3 said: and the vehicle speed (through the ECU), with no luck Try this setting, the out of the box Haltech value is much higher and reads weird Also if you're running the latest version of the firmware, there's a known bug with VSS doing a few thousand km/h lol Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979713 Share on other sites More sharing options...
R3N3 Posted May 22, 2023 Author Share Posted May 22, 2023 1 minute ago, Dose Pipe Sutututu said: Try this setting, the out of the box Haltech value is much higher and reads weird Also if you're running the latest version of the firmware, there's a known bug with VSS doing a few thousand km/h lol Yes, I did have the latest firmware, so I think that’s the issue! Also, no more haltech forum?? I joined that FB page too.. the fuel sensor issue on the IC7 also seems to be firmware related. For some reason the software isn’t updating it with the latest firmware… Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979714 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 23, 2023 Share Posted May 23, 2023 Hopefully easy fix! And yeah, a bit sad they removed the forum. Facebook is a bit shit, same questions get asked every week. 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979715 Share on other sites More sharing options...
soviet_merlin Posted May 23, 2023 Share Posted May 23, 2023 What the heck? Did they completely axe the forums and all content? Intentionally? This blows my mind. If it was intentional it seems so incredibly misguided I can't even comprehend it. Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979717 Share on other sites More sharing options...
R3N3 Posted May 23, 2023 Author Share Posted May 23, 2023 27 minutes ago, soviet_merlin said: What the heck? Did they completely axe the forums and all content? Intentionally? This blows my mind. If it was intentional it seems so incredibly misguided I can't even comprehend it. It appears so!! I solved a lot of problems just searching on there.. Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979719 Share on other sites More sharing options...
Looney_Head Posted May 23, 2023 Share Posted May 23, 2023 On 5/22/2023 at 12:43 PM, R3N3 said: Thanks! Funny that. My cert guy was the one who said I needed 1… let’s see what happens. sweet if they have said one then one it is 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979727 Share on other sites More sharing options...
R3N3 Posted May 24, 2023 Author Share Posted May 24, 2023 On 23/5/2023 at 12:05 PM, Dose Pipe Sutututu said: Hopefully easy fix! And yeah, a bit sad they removed the forum. Facebook is a bit shit, same questions get asked every week. Fixed the speedo issue. Funnily enough, my settings were around 5221 pulses/km and I think that was calibrated at 30km/hr. Verified the speed with a shitty app that lagged heaps, so probably wrong still haha but at least I’m not doing Mach 2 anymore. played with the idle a bit, as the tuner had it set at 900. The DBW makes this super easy and super stable! I backed it down to about 750/800rpm and it’s rock solid! just need to figure out the fuel gauge next! 2 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7979815 Share on other sites More sharing options...
R3N3 Posted May 30, 2023 Author Share Posted May 30, 2023 As part of my cert tomorrow, I had to update the HICAS lock bar, as there is some picky rules re. bars with welds. This is why I bought the PRP bar, it’s billet with no welds.. The bar itself is great but I feel there has been little thought on the actual application. I had to cut 10mm off the thread on the arms to get the toe adjustment anywhere near right. They say they are bringing out new arms for it but who knows Wel hen that’s happening.. I should have gone with a gktech full delete kit. 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7980018 Share on other sites More sharing options...
WR33KD Posted May 30, 2023 Share Posted May 30, 2023 You should have just run a non hicas r200 frame and arms and knuckles to suit, way less stress and it’s a way cleaner look under the back 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7980023 Share on other sites More sharing options...
R3N3 Posted May 30, 2023 Author Share Posted May 30, 2023 53 minutes ago, WR33KD said: You should have just run a non hicas r200 frame and arms and knuckles to suit, way less stress and it’s a way cleaner look under the back Yeah, I will investigate this. also, I will be getting a flex fuel sensor, so I will be getting me some of that ethanol you linked! Cheers! 2 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7980027 Share on other sites More sharing options...
R3N3 Posted May 31, 2023 Author Share Posted May 31, 2023 (edited) So the car failed the cert, however on really minor stuff: Exhaust is 1.9 decibels too loud (was 91.9db at 3200rpm and needs to be 90)- im just going to put a restriction in the exhaust to get a pass. i may quit down the exhaust long term, just want to get a good feel for it first.. I need to put a cover over the fuel top hat (factory one doesn't fit because of FPG top hat). ill just have to modify the factory one to suit. no airbag diagnostic light on the dash (as i now have the IC-7). i wish the IC-7 had more customisation here with different logos etc. but nope. I have ordered a little airbag logo light that i will install on the dash. I should have this remedied next week and finally be legally back on the road. Edited May 31, 2023 by R3N3 2 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7980065 Share on other sites More sharing options...
R3N3 Posted July 4, 2023 Author Share Posted July 4, 2023 As of today, the car is legally back on the road! I really need to get my fuel level calibrated.. 3 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7981012 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 4, 2023 Share Posted July 4, 2023 Congrats! How does it feel on the street? Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7981013 Share on other sites More sharing options...
R3N3 Posted July 4, 2023 Author Share Posted July 4, 2023 22 minutes ago, Dose Pipe Sutututu said: Congrats! How does it feel on the street? Really good! The turbo whistle is much louder than I thought it would be. It’s so much rougher than I remember lol. Spending too much time driving the smooth Skoda with heated steering wheel and seats, 360deg camera etc.. I just need to do a road tune to get it 100% perfect 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7981014 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 4, 2023 Share Posted July 4, 2023 I totally get this, with the MK2 Tiguan. Get into the R33 and it feels like a croc of shit. 1 Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7981016 Share on other sites More sharing options...
R3N3 Posted July 4, 2023 Author Share Posted July 4, 2023 20 minutes ago, Dose Pipe Sutututu said: I totally get this, with the MK2 Tiguan. Get into the R33 and it feels like a croc of shit. Best thing is the wireless CarPlay head unit! I just need to get an amp and speakers. Link to comment https://www.sau.com.au/forums/topic/483924-nz-r33-long-term-build/page/9/#findComment-7981017 Share on other sites More sharing options...
