Just found a little connector that it fits in, it tricks the ignition into thinking the key is in for like 30 seconds and I can turn the starter without putting my key in.
I can still start the car the usual way using my actual key. Very odd
Edited by oscian
On 17/8/2022 at 3:09 PM, Akshunhiro said:
Likely aftermarket immobiliser
Looks similar to the autowatch fob
Found a card in the manuals bag that has the override code for a mongoose brand system. Found the exact one in my car Here. I don’t seem to have the second little key for the immobiliser however.
OK update turns I could be a little slow, I have a nissan smart/intelligent key fob so I think the reason its starting without the key after disarming the immobilizer is because it has keyless start and is detecting the key next to me 🤦‍♂️.
Once I get it back from the mechanic ill test if I can start the car keyless like before except with the key put super far away to test the theory.
If it manages to start by just the immobilizer being disarmed and it has nothing to do with my nissan key then I might look at making it not do that.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
