On 8/17/2022 at 4:39 AM, Dimon said:
G'DAY
I have a question
And I need  some info
R33 Rb25det  S2
Camshaft  Tomei  264 lift 8.5mm
Are they   drop in setup
Without modifications  of  head
And how good are   they
8.5mm is designed to be drop-in, probably won't be anything much to write home about but it will presumably do something.
https://www.kelfordcams.com/index.php/nz/camshafts/nissan/rb20-25de-det
Better off with a set of more modern cams from Kelford. Email them about your needs and they will recommend most suitable cam profile. I have a set of poncams, they dropped in and did valve springs too. Only because that was al that available in 2009......
More lift is what you want
I would also recommend whatever you do you get cams that retain the NVCS. Being able to swing the cam even if it's fixed 15 degrees of advance is well worth the effort.
  • Like 2
Yes they are drop in like above i also have Kelford cam in my 33 you will also have to get your car tuned to get the most out of them i would speak to you tuner you might want larger injectors as well depends what other mods you have done to your engine lump idle doesnt mean it will go any better
  • Like 1
So this  my setup
Walbro 460 fuel  pump straight  from the battery
E85
370Z coilpacks
Injectors NISMO 740CC
Fuel pressure  regulator tomei
90mm throtle body
Front  mount intercooler
GTX3076R
38mm external gate
Top mount  exhaust  manifold
3inch  exhaust  straight
Greedy style  plenum
50mm blow off
Oil cooler
Aluminium  radiator
ARP head studs
Tomei  head gasket  1.2mm or 1.3mm
Tomei camshaft  264  and 8.5
Tomei camshaft gears
Z32 AIR FLOW Miter
APEXI POWER FC
APEXI  BOOST CONTROLLER
Edited by Dimon
the GTX 3076 will easily make over 320Kw on ethanol no need for cams as will only shift powerband up higher. My old gt3076 does 300kw on 16psi.
I am guessing you want more power?
Ditching the freddy plenum and 90mm throttle body will improve the torque & response everywhere.
Edited by robbo_rb180
  • Like 1
Yes I wanna  achieve  400kw
But for 400kw  I need a new  ECU
And bottom  but it will  cost min 4K
So now I wanna really  safe 320kw-330kw
But in the  future   I'll  go to the 400kw and less work  it will take
If it were my setup replace 90mm throttle body to 80mm to help your apexi air flow setup on your manifold increase your injector size if your going to be running E85.
My setup on my car runs 660cc injectors BP98 Wolf 550 ecu no air flow meter Hyper Gear rtr 43ss2 Turbo 272 Kelford cams Greedy ported manifold with 80mm T/B Lewis stage 3 ported and flowed head and it makes 473hp with 15 pounds boost so im sure with a couple of tweeks you can get similar power i do think you should go the extra mile and get a better ecu as apexi is getting a bit long in the tooth. I hope you get your car up to your expectations
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
