On 8/17/2022 at 4:39 AM, Dimon said:
G'DAY
I have a question
And I need  some info
R33 Rb25det  S2
Camshaft  Tomei  264 lift 8.5mm
Are they   drop in setup
Without modifications  of  head
And how good are   they
8.5mm is designed to be drop-in, probably won't be anything much to write home about but it will presumably do something.
https://www.kelfordcams.com/index.php/nz/camshafts/nissan/rb20-25de-det
Better off with a set of more modern cams from Kelford. Email them about your needs and they will recommend most suitable cam profile. I have a set of poncams, they dropped in and did valve springs too. Only because that was al that available in 2009......
More lift is what you want
I would also recommend whatever you do you get cams that retain the NVCS. Being able to swing the cam even if it's fixed 15 degrees of advance is well worth the effort.
  • Like 2
Yes they are drop in like above i also have Kelford cam in my 33 you will also have to get your car tuned to get the most out of them i would speak to you tuner you might want larger injectors as well depends what other mods you have done to your engine lump idle doesnt mean it will go any better
  • Like 1
So this  my setup
Walbro 460 fuel  pump straight  from the battery
E85
370Z coilpacks
Injectors NISMO 740CC
Fuel pressure  regulator tomei
90mm throtle body
Front  mount intercooler
GTX3076R
38mm external gate
Top mount  exhaust  manifold
3inch  exhaust  straight
Greedy style  plenum
50mm blow off
Oil cooler
Aluminium  radiator
ARP head studs
Tomei  head gasket  1.2mm or 1.3mm
Tomei camshaft  264  and 8.5
Tomei camshaft gears
Z32 AIR FLOW Miter
APEXI POWER FC
APEXI  BOOST CONTROLLER
Edited by Dimon
the GTX 3076 will easily make over 320Kw on ethanol no need for cams as will only shift powerband up higher. My old gt3076 does 300kw on 16psi.
I am guessing you want more power?
Ditching the freddy plenum and 90mm throttle body will improve the torque & response everywhere.
Edited by robbo_rb180
  • Like 1
Yes I wanna  achieve  400kw
But for 400kw  I need a new  ECU
And bottom  but it will  cost min 4K
So now I wanna really  safe 320kw-330kw
But in the  future   I'll  go to the 400kw and less work  it will take
If it were my setup replace 90mm throttle body to 80mm to help your apexi air flow setup on your manifold increase your injector size if your going to be running E85.
My setup on my car runs 660cc injectors BP98 Wolf 550 ecu no air flow meter Hyper Gear rtr 43ss2 Turbo 272 Kelford cams Greedy ported manifold with 80mm T/B Lewis stage 3 ported and flowed head and it makes 473hp with 15 pounds boost so im sure with a couple of tweeks you can get similar power i do think you should go the extra mile and get a better ecu as apexi is getting a bit long in the tooth. I hope you get your car up to your expectations
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
