RS4V Suspension
SLIXK
 Share
Not sure, but I'd bet on it being discussed before. The forum search isn't great but with search engines it works much better:
https://duckduckgo.com/?q=stagea+coilovers+site%3Asau.com.au&t=fpas&ia=web
One thing I'd suggest to consider is fitting some adjustable camber arms in the rear whilst it's all apart. Not sure if it's universal, but on mine it was wearing off the insides of the tyres in the back after fitting coilovers. Enough so that it got flagged in a roadworthy check.
I ended up getting "ZSS Rear Upper Camber Arms (Hardened Rubber) - S14/S15/R33/R34/C34/C35 × 1" from justjap and they seem fine.
Except that you really shouldn't do camber arms on their own without doing the radius arms also. And you shouldn't do radius arms without knowing how to make and use a bump steer gauge to make sure that you dial out the increased bump steer that you will put into the rear end by simply changing the length of the camber arms. I have posted extensively on this subject before.
  • Thanks 1
Hmmmm, thanks for chiming in! That is both good to know and a bit concerning. I know little about this, but my simpleton's impression was that lowering the car messes with the alignment and the camber arms help to undo some of that misalignment. Is that not true?
What effect does bump steer in the rear have? It makes sense on the front tyres to me, but I can't really picture it for the rear.
PS: If in doubt @SLIXK, listen to GTSBoy and disregard what I said.
PPS: If anyone has some search magic on hand to find GTSBoy's posts specifically I'd be interested in that.
Just search GTSBoy bump steer.
The kinematics of the wheel are controlled by the arcs that the upper, lower and radius arms move through.
You're already up to speed with what happens if you just drop the ride height on stock arms. The wheel swings up and -ve camber increases and you get the undesired effects of that. So, you lengthen the upper arm to dial out the camber. The arc that the top end up the upright now follows is longer, right? But the radius rod is still the same short length that it was before, and it pulls the front of the upright inwards as all these arms go up and down. This literally steers that wheel. It changes its toe in-out as it goes up and down through the arc of travel.
So you need to have an adjustable radius arm also. You mount a mirror onto the hub and you shine a laser at it, reflected back onto a piece of paper near the laser. As you swing the arm up and down**, the laser will trace a shape on the paper. You want that to be as close to a straight vertical line as possible, which shows that the wheel is only going up and down, not also steering in-out. You then set the radius rod length to minimise the sideways deflection of the laser path. This is enormously time consuming, and takes several iterations to get right, because when you adjust the radius arm length you also tweak the camber a little. So you have to go around and around a couple of times to get the camber where you want it and also minimise bump steer.
**Doing this requires that you support the car and can independently support the hub and swing it up and down through its travel. So you have to disconnect the rear strut. You need to know exactly where the hub is supposed to be wrt the body when at correct ride height, because this is the centre point of the arc that you need to run up and down from.
  • Thanks 1
  • 3 weeks later...
On 23/08/2022 at 10:43 AM, SLIXK said:
Anyone know what type the RS4V uses I want to purchase bc golds, and give it to the shop that currently has my car to install it for me with new wheels. RS4V
Mines an RS4V as well.  Personally I use the Tein Flex coilover.
But i'm pretty confident this is the page to checkout, with the eyelet type mount.
https://bcracing.com.au/collections/nissan-stagea-rs-x-four-awd-eyelet-type-rear-mount-wgnc34-96-01
I'll be under the car on the weekend so can take pics if you need something to compare/refer to?
I was told by a few it’s eyelet so I just purchased eyelet ones, will have to see when they arrive.
Edited by SLIXK
 Share
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
    • Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car. So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
    • What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
