Transgo Shift kit RE5R05A (HD-2 - for a 370GT coupe *** Yes, I have read all the old posts***
Hi guys,
I have had a v35 for nearly 5 years and recently sold for a v36 coupe upgrade.
I have purchased the shift kit and am waiting for it's arrival.
My query is around finding a place/person in Melbourne to install for me.
All the old forums on this are 10yrs or so old so I don't want to msg those individuals who may not even like these cars anymore haha.
I have obviously called around some shops out west where I live but haven't gotten very far/they all want to see it and I'm struggling to even get a quote...
Thanks all,
Feel free to email me even if you know a place/have done it/can do it etc etc on [email protected]
Thank you for the replies gents, which shop is that Vee37? I have tried Hoppers Transmissions and Diffs and Techtrans to no avail. I'm hoping to find a shop that has maybe done it before.
Thanks for the reminder Paul, I'm tossing up between Matic J or S, but I am pretty sure from reading Matic S fluid is newer.
I have read a lot of US forums/g37 forums BUT I have seen old posts on here from like 2012 where guys in Melb were offering prices, hoping they'll reach out to me if they still do them.
I was ltalking about the previous post, referring to estimates in the US.
On 8/25/2022 at 5:48 PM, V35_Paul said:
on the US forums they say it takes a shop 4 hours.
ask their hourly rate.
Plus fluids too 👍
Matic S is a lower viscosity fluid, if the manual specifies J, make sure it will happily run on the lower viscosity S before you use it.
  • Like 1
Sonicii - I have read on many forums that Matic S replaced J? Is this not true, I found a shop that can do it but they say in their quote they won't use nissan special oil (i,e matic S/J), do you know much about these trans and if that will be ok?
Not exactly.  Matic S is a newer fluid.  Many Transmissions that specified J before S came out, can happily run on S, but they are not the same fluids (same with NS2/NS3 with Nissan FWD CVTs).  For example, my Infiniti specifies Matic S for the transmission, but Matic J for the transfer case as it requires a higher viscosity fluid.
Sorry, I don't know with any certainty if the RE5 can happily run on Matic S, plenty of forums and web pages say it can..
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
    • Excellent...maybe even instead of RB rebuild start with 6L LS and add boost for good measure!
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
