Has anyone tried the rb26 greddy pulleys on an rb25?
As far as I can see online the alternator and water pump should fit, not sure about power steering though. Google won't tell me the sizes of the pulleys either so I'm unsure.
https://www.sau.com.au/forums/topic/483982-greddy-lightweight-pulleys-on-rb25/
Just to add to this, the RB25 S1/S2 power steering pulley is 3 rib where as the RB20, RB26 & Neo have a 4 rib. This link mentions it and and the offset GTSBoy mentionned.
https://www.facebook.com/RossPerformanceParts/photos/a.1384131785198180/2713886952222650/?type=3
Edited by TurboTapin
  • Thanks 1
On 30/08/2022 at 4:38 PM, TurboTapin said:
It's snake oil.
They do look cool though
On 30/08/2022 at 6:55 PM, niZmO_Man said:
Drill holes in your existing ones? (i'm joking, don't do it)
Lol I'd rather pay for the greddy ones
I have used the ebay/greddy knock off kit. Don't bother.
Bought the nz performance water pulley - good item, but hey only bought it cos i like wasting money on car parts. Dont expect anthing crazy like "noticeable performance gain", come on :p.
  • Like 1
  • Thanks 1
On 8/31/2022 at 4:00 PM, niZmO_Man said:
use spacers to move the pulleys?
FYP 😜 I want to see the carnage
The pulleys are a waste if just wanting fancy blue ones. Remove your current ones, clean them and get them anodized.
Only time to change is when required to under drive power steering & alternator if spending alot of time in high rpm (ie...on race track)
  • Haha 1
On 31/08/2022 at 4:00 PM, niZmO_Man said:
you could use spacers to move the pulleys? (I'm joking, don't do this)
In the link you shared it says that the alternator and water pump pulley offsets, groove count and diameter are all the same across RBs. If that's the case I could use those 2 pulleys and not worry about the PS pulley,  is that correct or am I completely missing something?
Cheers mate,  I don't expect anything noticeable, maybe 0.1% but it looks better and I'm changing a few things anyways so I can make it look a bit ricier in the process.
Lol I'd prefer to keep the carnage to shredding a set off on a "private road"
On 31/08/2022 at 5:31 PM, The Bogan said:
Paint yours blue
+25kw
Lol sounds too good to be true
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
