Hey guys, I'm currently rebuilding my first skyline from the ground up. I was wondering what the best route for the cooling system would be and what are people's current setups and power levels. I'm hoping to hit around 400hp when I'm finished but want to know if I should use an aftermarket rad and shroud with electric fans or if the stock rad and fan/shroud is the way to go?
I've read some posts and seems alot of people are getting higher temps when going aftermarket and even higher when using the AC too.
As the title suggests I'm building a r33 gtst with a rb25det.
Any tips or information is appreciated thank you!
Edited by Disco18
https://www.sau.com.au/forums/topic/483984-r33-gtst-cooling-system/
There is no issue with the standard fan up to 300kw, you will probably want a larger radiator to go with it.
Among the most common cooling issues is unnecessarily changing the stock fan for a poorly set up electric fan.
  • Like 3
  • Thanks 1
I used a Fennix radiator in mine with stock fan and shroud with the stock undertray
I was making around 500hp
Never had a issue......with coolant temps
I did have a oil cooler though which would have helped
  • Thanks 1
Well thats good to know, I was looking at getting a fennix but have heard they are hit and miss, but i think that's more because people were using a poor electric fan setup. Do everything still fit or was there some adjustments you had to make?
Thats good to hear, I didn't want to be one of those guys who pays 300 for fans and shroud when the stock setup is actually just as good if not better anyway. Any radiator recommendations? I was looking at fennix because they are a little cheaper than a koyo but still not 100% sure if they are a solid choice.
As others have said an upgraded rad and stock fan & SHROUD will have no issues. If ever swap to electric fan use a quality spal or maradyne fan with a properly designed shroud.
Biggest thing is bleeding the system properly to remove all air pockets, a vacuum bleeder does a pretty good job first time.
  • Like 2
  • Thanks 1
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
