Hey guys, I was hunting around on here and found a an old thread in regards to this topic but it hasn't had any new info or comments so I'm trying my luck to get some more up to date info.
I am in the process of building a R33 GTR, while the engines out to go a bigger sump, head drain etc. I am looking at the front diff thinking it's stupid not to do it while it's out. So down the rabbit hole i've gone, after speaking to my diff builder he has said when making over 500kw you should be looking at doing the rear. Yes I know you can just leave it stock, but I am planning to do the rear as well as the front now.
My car is a street car and most it's time is seen on the street. From past threads and speaking to GTR owners it really seems like the Nismo GT Pro is a very track orientated diff. I am wanting something that is quiet but performs better than a stock diff. The Quaife is relatively maintenance and sounds like it is better suited for the street. But I am curious if anyone has a Nismo GT Pro 1.5 way in the rear of their GTR that is a mainly a street car, the guy building my diff has suggested he can wind it back and make it more tame for the street but said there will be some noise and some wheel hoping occasionally. Has anyone come across this? Has anyone run both? I would love to hear opinions and feedback if you have run either.
One thing I found is the guys running the Nismo GT Pro are predominately race cars, mine's far from that.
Cheers
There is absolutely nothing wrong with the standard diff (assuming you don't have the vspec ALSD), Nissan were kind enough to put a proper race spec diff there from factory. Did your engine builder have any specific benefit to go with the advice to change it?
It is possible (but not particularly likely) that the factory diff centre is worn after 30 years, but if so it is a simple maintenance job to reshim the centre back to either original tightness, or if you want it to be difficult to drive in carparks you can get it tightened up more than factory.
We use a tightened version of the original diff in the race car and have never had an issue with its ability to lock up when needed
  • Like 1
Yes correct, sorry I should of mentioned it is a non VSPEC. So the diff builder has explained the standard GTR diffs often wear out on the passenger side bearing and the bearing just ends up spinning on the shaft. He has said he can rebuild it to standard build and tighten it, but he doesnt recommend it in higher HP cars. Because it is a weak spot in the GTR rear diffs. I will say that is something I am trying to avoid, wheel hopping in carparks, that would do my head in!
I don't doubt that the standard diff is capable and can be setup correctly. But the way I see it, if its prone to doing the side bearings lets just eliminate the problem
On 9/5/2022 at 6:21 AM, Dion_M said:
Out of curiosity experiences have you had?
I built a franken-helical for my R32 after experimenting with lots of other options. For a street car, they are nearly the perfect diff.
I also corroborate Duncan's input, which is that the factory 2-way clutch type diff is an excellent diff that does not need to be upgraded and actually does not have the bearing "weakness" that your diff builder claims. The bearings will actually be the exact same part regardless of what centre is in the diff anyway, so I'm none too sure what sort of cane toad he has been licking to come up with that story.
I have a nismo 1.5 pro and I am old now and wouldn't use it in a street car. It's an amazing diff though, just be too annoying for weekly drives.
Rebuilt stock gtr is great in the rear, it still skips slightly on tight tight slow turns but very minor.
Drives both rears perfectly.
On 9/5/2022 at 7:55 AM, BK said:
I use Quaife front and rear on the 600kw+ 32. Wouldn't use anything else after swapping to these as they are brilliant
Out of curiosity what type of car is it to be running 600kw, drag, circuit, street? What did you do for the gearbox?
All of the above - built to be an all rounder. Transmission is an H pattern dog box. Read my eternal money pit build thread for full specs on first page
Don't overthink the diffs, buy the Quaife - nice on the street, excellent grip, turn in is great and locks hard when it has to.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
