Righto, who's  already forked out their folding for a set of the newly announced PRP vented/baffled cam covers?  I will but need to let the sting of 2 months hard part gathering to subside a little before I take the plunge!
They will be an awesome thing if they deliver what they promise being minimal oil leaving the breathers.  Saves having to have a catch can the size of a fuel tank in the engine bay!
https://www.platinumracingproducts.com/products/platinum-racing-products-rb-twin-cam-baffled-cam-covers
Platinum Racing Products - RB Twin Cam Baffled Cam Covers
https://www.sau.com.au/forums/topic/484085-prp-baffled-cam-covers/
But it looks RB tough...!
Supra guys just run catch cans the size of catch cans, looks weak. Even my GTS-t shit box has a 5.5L catch can oil tank LOL
  • Haha 1
I'm in the process of transplanting my fuel tank into the engine bay specifically  as a catch can, should look nice.
  • Haha 3
Everyone knows a RB when they see a massive catch can, breathers, left right and centre, monitoring for oil pressure, oil temp, etc. and more monitoring on everything.
700kW Supra, cam covers -> intake pipe, meh.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
