Hey guys this isn’t a fab question but I couldn’t find the precise place to put this.
how much money and time would it take to get an engine converted with hemi heads and pistons/is it even possible. I’m looking at doing this for an RB26 build I’m putting together
also if anyone knows of somewhere in SA that does this could you leave a link or a name for the place.
thanks I’m advance
https://www.sau.com.au/forums/topic/484094-probably-not-a-fab-question/
What do you mean "converted with hemi heads"?
Let's make a few points.
  • I'll presume you do not mean "hemi" as in "Hemi"....ie Chrysler heads. That's what a lot of people would mean when they say "hemi heads".
  • I know and totally understand that the concept of hemi heads is much wider than that. Example such as ALFA twin cams going back to the 50s spring to mind, amongst hundreds of others.
  • Are you aware that there's not really any such thing as a 4 valve hemi combustion chamber? Have you ever seen one? There isn't room to fit 4 valves in. That is is why 4 valve heads are all pentroof design (or some variation thereof).
  • 4 valves provide more valve/port area than 2 valve heads do, which is why they exist.
  • Going backwards from 4 valve pentroof, to hemi 2 valve seems.....backwards.
  • Like 1
Please oh please be Chrysler Hemi heads.
  • Haha 4
  • 4 weeks later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
