When you changed across, did you re-use the factory oil return pipe? I thought there was a physical difference between factory and garret cores, which is why these exist: https://justjap.com/products/xtr-turbo-oil-drain-adapter-garrett-t28
If it fitted up fine, I can only suggest pulling the oil drain again (real pain) and checking the gasket and mating surfaces
Thanks Duncan.
I did re-use the factory line and it seemed to fit fine - the heat wrap was butted up against the compressor housing (as with the OEM turbo) but I did not have to force anything. The rear turbo oil return pipe is not leaking maybe because it is a different shape?
I've resigned  my self to checking the gasket and mating surfaces as you suggest. Is it possible to do this without removing the turbo? I seem to remember having to fit the return pipe before the oil & water feed pipes so I don't know whether I will be able to drop return pipe enough to either slide in a new gasket or view the mating surfaces.
If you're using paper gaskets one thing you could try is spraying this copper spray on a new gasket after cleaning off the oil to see if that improves things: https://www.permatex.com/products/gasketing/gasket-sealants/permatex-copper-spray-a-gasket-high-temp-sealant-12-oz/
I only suggest this if it's less effort to slide a paper gasket in there somehow instead of possibly pulling apart most of the turbo support infrastructure to replace the return pipe and gasket.
Sorry to say, it is very difficult to get the hose off with the turbo in place because the 2 hard lines don't have much gap between them, it is highly likely to split the rubber hose. Unfortunately taking the turbo off will be easiest.
Thanks Duncan.
Based on my experience of removing the OEM turbo I think it may be possible to remove the rubber hose - I'm just not sure if I will be able to either remove the metal oil return pipe or drop it enough to replace the gasket.
I guess I might as well try this first if I have to remove the turbo anyway. It would just be nice to know it is possible before I try 🙂
34 minutes ago, proline said:
Thanks for the suggestion Joshuaho96.
That gasket sealant has temperature range of a max of 260 deg centigrade - would this be high enough for a turbo oil return flange?
It's not directly exposed to exhaust gas temperatures and it's presumably carrying a bunch of oil in it so that will help bring temps closer to 100C. So it should be fine. If you have to pull everything apart anyways you can verify you have the right pipe, make sure both flanges are flat, then use this sealant on top of a clean/flat/new/etc gasket to try and give it the best odds of sealing properly. Also worth mentioning that this copper spray sealant is probably not great to breathe in, make sure to use outdoors like rattlecan and use some cardboard to catch overspray.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
