Interesting. Those turbocharged engine diagrams usually has all the boost go straight into the intake valve lol. So i thought they were the same thing.
  • 3 weeks later...
Alright, i connected everything properly, but my car isn't boosting past 7-8psi. Any ideas?
3 Port Solenoid is working, i hear it clicking.
Stock ECU or did you end up popping in that Haltech Platinum? I'm presuming the latter, if so have you set up your output, boost maps, etc.?
yessir, haltech platinum is in. I did multiple runs and my manifold pressure (boost pressure) never exceeds 8psi. All the settings are correct.
Open boost with 33 hz. No matter what duty cycle % i put, it dosent change boost pressure.
1 hour ago, kevboost7 said:
im about to just drive this car off a cliff
I swear i hooked up everything exactly like the diagram. could it be a boost leak?
No as you are making wastegate pressure. If was leaking it would creep.........
Above plumbing is the way to go. Don't run lines back to plenums, exactly like the above. Short runs of hose, super easy
Check what MAC valve you have as some can be different with how they work. Greddy are backwards to normal in my experience.
Connect reference line to wastegates directly to see what it makes, do a run and log it. Then plumb in the solenoid its internal gate so can only go one way. Run it and log it. Add 20% to whole duty cycle table do a run and log it if get a change add 5% more do a run and log it. Do this until achieve target pressure.
Will need maybe 20-30% Duty cycle to see any change in pressure from actuator preset.
If this doesn't work take it to someone who knows what they are doing, its a super simple setup that has been tried and tested for well over 20 years.
1. I thought this turbo pressure line comes from the plenum? Is there a way to get the turbo pressure line near the turbos?
2. How do i plumb in the selonoid in its internal gate so it goes only 1 way?
This is just a part of learning how to modify a car.
1. When it comes from the plenum (before the throttle bodies) it accounts for the losses through the intake piping. Personally I do not think this is your problem.
2. I think the suggestion is to basically completely re-do the vacuum lines instead of using the factory setup. So basically you would plumb the turbo pressure line just after the twin turbo merge pipe. Then you would disconnect the factory hoses going into the wastegate and put in your own hose with a tee piece to join it all together.
I kind of find it hard to believe that the factory plumbing won't work for what sounds like a mostly normal configuration.
As others have said you should post clear, well-lit pictures showing what you've done. It may also be that your issue is wiring, a bad solenoid, your MAC valve actually has different port numbering/orientation than the normal ones online, etc.
This would require you to drill and tap into the alloy of the merge pipe, to put in a nipple, or weld a nipple onto the hot pipe after that point.
The reason here is that the drawing you showed, with a line coming from each compressor housing, teed together to feed the solenoid valve, only works when you have tapping points on the compressor housing, which you won't have.
I really struggle to understand what you mean by "only goes 1 way". What was it you're trying to do there?
I was thinking of putting a nipple into the factory rubber hose or the aftermarket metal pipe after the merge pipe but yes regardless it's kind of annoying and impractical. I also really don't think it should be a problem if the factory boost solenoid was working prior to this.
Oh, yeah, there's no reason to avoid using the existing plumbing. What is there can be used to make it work properly. You just have to plumb it up correctly.
I re-iterate to the OP. If it is not working, it is NOT PLUMBED UP CORRECTLY.
And, to follow on from Joshua's repeated suggestion that the MAC valve might have differently labelled/functioning ports compared to the usual MC valves, I posted extremely clear instructions on how to work out which port is which, earlier in this thread. So there should be no excuses there either.
Hey guys, sorry i just got back from my trip to greece.
I was able to take a video of everything. See the link. Dont judge me for the spaghetti wiring/hose mess right now lol
This is what your setup is:
Port 1 - atmospheric vent
Port 2 - wastegate port
Port 3 - Pre-throttle boost source
Compared against this diagram:
So the vacuum line setup actually seems ok to me? You might need to use an air compressor or just blow through the hoses. When it's off it should connect port 3 to port 2. When it's on it should connect port 1 to port 2 instead. Set it to 90% duty cycle on the Haltech and see if that is actually happening. Don't run the engine when doing this experiment and remember to set the values back to something normal afterwards.
Put 14 psi into port 1 vacuum line and verify you can hear it venting into the intake piping before the turbos. It shouldn't hold pressure substantially.
If all the function tests check out set a boost fuel cut for something very conservative like 2 psi over wastegate boost and set the solenoid duty cycle to 90%. If you still get stuck at wastegate boost then try just running with port 2 open to atmosphere with the same conservative boost cut. Before you actually set that boost cut the way I describe see if it works at 2 psi of boost for example. You don't want to find out after the fact whether the boost cut didn't work as intended. Make sure to set a large hysteresis as well in the fuel cut so you aren't bouncing off of it.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
