  • Replies 76
UPDATE:
Because of my awful timing, the Dyno day has been re-scheduled to the 23rd. Same time, same place. Bring your friends but leave your Camry's at home.
Any questions, call me on 0417009831
Cheers.
hey I was just wondering fom reading this, if the place you are referring to is the same place as pictured in the link that brendanf posted, then what are the 4WD cars gonna do?????? I know if I owned a GTR that I'de want "@ all 4 wheels" figures............(although I have been informed by a mate of mine who owned a GTR, that from personal experience there was no difference to the power figures when run in 4WD & 2WD mode sooooooooooo.......... :))
Just a thought :)
Unigroup Engineering:
17/17a Amax Ave, Girraween, NSW, 2145
PM or email me if you need any details.
Hope this helps.
So far we have:
2RISMO
BY BY
BRENDANF
ROBO
MOANIE
CARLO
400HP
BENM
STEVE_GTS4
BROKEN
franks
GooGZ
Duncan
armbrusb
Who else?
Thanks
Im very interested in attending. Only got my GTS-T 2mths ago and i wouldn't mind knowing what it can do. Scares the shit outta me as it is and its not far from stock :uh-huh: Either that or just rock up and take some pics etc.
Only 25min drive from me also (At Penrith).
Is it possible that the organiser can send everyone a reminder email about this as being 10 days away im likely to forget (dont visit this forum much although now that i have registered i probably will).
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
