  • Replies 76
UPDATE:
Because of my awful timing, the Dyno day has been re-scheduled to the 23rd. Same time, same place. Bring your friends but leave your Camry's at home.
Any questions, call me on 0417009831
Cheers.
hey I was just wondering fom reading this, if the place you are referring to is the same place as pictured in the link that brendanf posted, then what are the 4WD cars gonna do?????? I know if I owned a GTR that I'de want "@ all 4 wheels" figures............(although I have been informed by a mate of mine who owned a GTR, that from personal experience there was no difference to the power figures when run in 4WD & 2WD mode sooooooooooo.......... :))
Just a thought :)
Unigroup Engineering:
17/17a Amax Ave, Girraween, NSW, 2145
PM or email me if you need any details.
Hope this helps.
So far we have:
2RISMO
BY BY
BRENDANF
ROBO
MOANIE
CARLO
400HP
BENM
STEVE_GTS4
BROKEN
franks
GooGZ
Duncan
armbrusb
Who else?
Thanks
Im very interested in attending. Only got my GTS-T 2mths ago and i wouldn't mind knowing what it can do. Scares the shit outta me as it is and its not far from stock :uh-huh: Either that or just rock up and take some pics etc.
Only 25min drive from me also (At Penrith).
Is it possible that the organiser can send everyone a reminder email about this as being 10 days away im likely to forget (dont visit this forum much although now that i have registered i probably will).
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
