  • Replies 76
soz but i didnt read the whole thread but are us AWD fella's able to have a run ???
yep as long as u know how to make it be 2WD temporarily :)
I think I'll be there...
can you be a little more accurate with the information? :)
Thanks guys.
Car had manifold/plenem, fuel rails, injectors, turbo and Front bar removed ATM.
May rock up if car is back together - so I can blow that dyno off it's Lamda probe.
Stay tuned - may rock up in poor as piss VL turbo !! ahhhhhhh
Unigroup Engineering:
17/17a Amax Ave, Girraween, NSW, 2145
PM or email me if you need any details.
Hope this helps.
So far we have:
2RISMO
BY BY
BRENDANF
ROBO
MOANIE
CARLO
400HP
BENM
STEVE_GTS4
BROKEN x3
franks
GooGZ x2
Duncan
armbrusb
XrSiSt
HoeTrain
Who else?
Thanks
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
