While looking at diff options saw that kudos have a sale on nismo units. Just wondering if anyone can give me some reviews on the. I can get a 2 way rear and 1.5 way front. Car will be used on street but built for roll/drag. Goal is 8 second time slip.
https://www.sau.com.au/forums/topic/484102-nismo-lsd/
Plus a couple of other factors..... the Nismo 2-way is still pretty miserable to live with on the street. The Nismo Pro is a much better option - you can adjust it somewhat.
I would defo prefer a Quaife in the front. Almost certainly prefer a Quaife in the rear. The only time a helical will let you down is when you prop a wheel up in the air. Are you going to twist a GTR chassis enough for that in a drag race?
https://www.sau.com.au/forums/topic/484102-nismo-lsd/#findComment-7970860
Quaife at the front, hands down. The best mod you can do to these things. It should be mandatory if the engine comes out, it can’t go back in without one installed.
I have a GT pro 1.5 way in the rear and even set to soft it’s pretty cranky in servo’s and car parks. The OS Giken lsd oil, from memory 80w - 250 calmed it down alot.
A bit of character never hurt anyone. 👍
  • Like 2
https://www.sau.com.au/forums/topic/484102-nismo-lsd/#findComment-7970875
  • 3 weeks later...
Had a very long chat with Will from JHH. He explained in great detail the real world difference between the types of diffs. I’m going Nismo pro diffs both ends. I know they will be clunky and rough in tight slow turns but when you aim for an 8 at the quarter mile, you have forgo some comfort. I’m trying to put allot of power to the ground. Clutch diffs will be the best choice to do so.
  • Like 1
https://www.sau.com.au/forums/topic/484102-nismo-lsd/#findComment-7971629
My mechanic has led me to the same result but for a very different use case. I will be going Nismo Pro front and rear when the diff rebuilds are done early in the new year
  • Like 1
https://www.sau.com.au/forums/topic/484102-nismo-lsd/#findComment-7971633
11 hours ago, khezz said:
I’ll see how I go. Looking at allot of the videos, it’s not that bad. It’s like going to E85 and complaining about fuel economy. It’s all about smile per gallon.
The name of the game when it comes to stuff like E85 is thermal efficiency, not mpg. Of course mpg will be worse, the volumetric energy density of ethanol is less than gasoline. I'm willing to bet with most if not all turbo RBs going to E85 is a net benefit for thermal efficiency.
https://www.sau.com.au/forums/topic/484102-nismo-lsd/#findComment-7971646
I wouldn't even think that it is inherently "thermal efficiency", so much as just being able to operate in a manner that is simply not possible with high octane petrol alone. I mean.....no-one knows what the thermal efficiency of the engine is operating at the boost or ignition advance (that you can run with ethanol is) when operating on petrol, because you only get 2s of operation then the engine blows up.
https://www.sau.com.au/forums/topic/484102-nismo-lsd/#findComment-7971647
3 hours ago, 33GTRV said:
make sure you are sitting down when you go to buy the DSS shafts. I was when i got them 18 months ago and nearly fainted.
Shortly after that i seen speedtek were making a 300m billet shaft!
Oh I have the prices. Speedtek make only a part of assembly. Great product, I agree but you are still left with a lot of weak parts that are 30 years old. DSS make a replacement for the entire assembly. So everything is brand new and will handle anything I through at it.
https://www.sau.com.au/forums/topic/484102-nismo-lsd/#findComment-7971663
1 hour ago, GTSBoy said:
Not sure how that's true. We're just talking in a tangential direction.
It’s all about “smile” per gallon. I was just making a comparison about making some sacrifices for overall enjoyment of the finished product. Slight humour. That’s all.
  • Like 1
https://www.sau.com.au/forums/topic/484102-nismo-lsd/#findComment-7971667
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
