When i was going to do a oil change on the front differetial of the r32 gtr, i took my finger in the drain plug hole and to see if there was metal flakes in there. By my suprise it felt like there was gravel in the bottom of the differential. I took some out and there wasnt gravel, it was like white small crystals in there.(looked like gravel first) If i rolled it between my fingers with some force it melt away or got crushed pretty easily.
There has only been a little bit of oil in the bottom of the differential for a couple of years because the car has just been sitting and some oil were drained because of engine rebuild and axels replacement. I belive its just the oil and condensation/water that's in there, that created these small things that looks like small white stones/crystals, what do you think?  Have you seen this before? I've worked with alot of car's but never experienced this.
I was about to remove the diff cover but after removing all the 10 bolts, the cover still was glued on there hard as fu##. So i thought i could put some new oil in there, drive a few miles, then drain in and put some new in again maybe? I cant belive that the gears in there will take damage from this?
45 minutes ago, joshuaho96 said:
Possible it's calcium additive from Shockproof gear oil.
39 minutes ago, Duncan said:
Either way, if you can crush it with your fingers it won't directly damage a gear. I'd do as you suggested, fill it with something cheap, run a few klm, flush and refill.
Thank you guys. I really appreciate your help and support/thoughts.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
