As I went to paint my engine bay I had to remove the entire subframe and after looking at it for a little bit I then started to compare with pictures from others and their R33s, and mine looks different to theirs! What I mean is, the two faces where the engine mounts bolt up are completely in-line with the entire frame, whereas all other R33 GTST pics I've seen have the locations sticking further outward (towards the front) and are in-line with the forward-most bolt. I am attaching a picture of my subframe (LEFT) and a random R33 GTST subframe (RIGHT). My chassis is an ECR33 factory spec 2 GTS-T RWD. Is this some sort of oddball that left the factory or has the previous owner done a subframe swap? If so, I cannot imagine how an RB20/25 would fit inside the bay with the mounts situated close to 10 centimeters back towards the bulkhead.
Interestingly there is not a single thread or video talking about such differences so I am coming here for your advice.
https://www.sau.com.au/forums/topic/484135-r33-gtst-front-subframe-differences/
Gosh darn it, it's already been hell finding the missing parts for this car, now a subframe?! Will have to modify the mounts or the subframe then but I've got no idea how I would get the motor to sit like OEM. What a mess. 😢
So just a little update for anyone wondering, this has been 100% confirmed S15 SR20 front subframe. The entire rest ofthe front suspension is bolt on, control arms, R33 steering rack, hubs.
While I'm still looking for a GTST subframe I decided to make my own adapter brackets for the engine mounts, similar to the kit ISR sells but just the two mounts. I got the angles and distances right (the bolt hole centers on the adapter brackets need to sit 125mm FORWARD of the S15 mounting holes!) and the driver side bracket needs to be angled slightly more than the other.
However even with these, I cannot mount the custom turbo oil return line I have made for the HX35. The tube bends too far out and clashes with the S15 stock mount point. For this to work, a significant portion of that point will need to be cut out just so the pipe can go through it. Definitely not something I want to do.
Thanks for the offer, but I have already found a 25det r33 front subframe from the UK and it's already on its way to me. Even still, I am slightly worried the engine mount and bracket combination might be wrong. Why did Nissan make so many different  variations of parts on these damn cars?!
They didn't, really.
There's cars based on the R chassis (ie, Skylines Stags) and there's cars based on the S chassis (Silvias and Ceffies). And there's 4 cylinder engines that were mostly in the S chassis cars but sometimes turned up in the nasty budget versions of the R chassis based cars. And there's the RB engines that were pretty much exclusively in the R chassis cars.
There are engine mounts for each type of 4 cylinder engine in the S chassis cars (CAs and SRs). There are engine mounts for the 4cly engines in the R chassis based cars (probably the same as for the S cars). And the RB engines have a couple of different types of mounts - essentially the RB26 and all the others. You can pull an RB25 out of an R34 and drop it and its mounts into an R32.
This just keeps getting worse and worse. I'm at my wits end with this shitbox already regretting getting a Skyline. So I finally got the R33 25det subframe shipped to me from the UK and when I test fitted it what do you know IT ALSO DOESN'T FIT!!!
I'm throwing a tantrum here but rightfully so. Can someone tell me what in the world is the problem? Is the problem the fact that its a 20 block? I assumed their mounting locations and bolt holes are identical across 20/25/26? The rubber mounts themselves are not the issue as these are  BMW mounts 100% identical to the Nissan square ones that came (they were torn and unusable). Regardless, the problem is the surfaces are not remotely parallel to each other so it's not the rubbers.
I'm suspecting it's the metal brackets. The person I got them from said they were from an RB20DET and he assured me they would fit a 25 block also, which in turn would logically mean they would fit an R33 chassis?
Unfortunately I am out of funds for this kind of crap so tomorrow I will be trying to cut these where I have marked with yellow lines and welding a new gusset. My understanding is that the oil pan's bottom naturally is parallel to the ground and to the subframe so I'm using that as a guide. I don't know how wide the gap needs to be between the oil pan and the subframe either. What a headache 😖
OK, so firstly, RBs do not sit parallel to the ground in their engine bay. I don't have an rb25 in an r33 handy to check what angle that combo sits at. A possibility is that you have the brackets on the wrong side?
Secondly, I'm not sure it matters but the the mount brackets look like rb20 not rb25. rb25 look like https://www.jdmgarage.com.au/shop/engine/engine-accessories/engine-crossmembers-and-mounts/rb25-engine-brackets-pair/. Also note the mounts you are using don't have 2 studs at the subframe end but I guess that is your choice
I know the engine sits tilted towards the passenger side but the oil sump itself is tilted also and it looks to be parallel to the subframe and ground.  I also thought I had the brackets wrong way round so I switched them and the bolt holes did not line up at all, so that wasn't it.
After further research it appears I do in fact have RB20 mounts which are paired with the rectangular Nismo rubbers (40mm high), and the RB25 mounts come in two kinds, cast aluminium or stamped steel that are paired with the big circular rubbers like in your link.
None of this was really documented anywhere so hopefully this thread will shed some light for people in the future.
  • Like 1
Need to use the matching bracket to subframe.
r32 cross member to rb20 brackets
r33 cross member to rb25 brackets
r33/rb25 from memory have 2 types of bracket a steel and cast aluminium.
Project cars are fun aren't they.........
  • Confused 1
Last update to this, I'm probably the only person who's ever going to be in this pickle since I know you guys in NZ/Aus have an abundance of the right parts, but still I had to improvise because shit is just too hard to get and overpriced. Ended up modifying the RB20 brackets and they ended up really nice, close to OEM and the motor sits good in the engine bay. It may look cocked to one side but that's because I was supporting it with my jack at the rear of the sump. I am confident once I get the transmission on and its bracket, it will line up true. I even slapped the head on it and tested my rear head breather, it has plenty of clearance from the heater hoses and bulkhead!
312709579_3015904008555769_8129993717735555993_n.thumb.jpg.7ca19095ee21d8de3c5f38d45fc35c54.jpg
310980571_651384669725199_423654037759109634_n.thumb.jpg.ab9bc505467e56ad9053ce3237a86b85.jpg312705278_650613976709740_1390925090055558928_n.thumb.jpg.0040f57e61830c5a880e9d8a92ff403d.jpg
Edited by Neostead2000
  • Like 1
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
