Hi there , I'm new to forum and new R33 owner , based in NZ .
I have noticed this component under the center console , it has the red line through it . What does this component do , indicates what ??
Appreciate your collective help .
https://www.sau.com.au/forums/topic/484136-g-sensor-r33-series-2/
Expand
The AWD or A-LSD system uses it to determine lateral g of the car and adjust the transfer case lockup or A-LSD lock pressure accordingly.
If that is your G sensor in the pic, it does not have the high impact red line showing.
If yours has a more obvious red section in the centre glass, it has had a high G impact. However, the shock indicator is physically separate to the actual g sensor electronics and is only an indication that the G sensor might be faulty. If your ATTESSA is working OK I would not worry any further
Expand
Thanks ,  I have A - LSD , and the sensor has the redline showing so will that mean that the A LSD wont be working ??
Expand
No. Not necessarily. Duncan told you that already....
Expand
My underline and bold emphases. Just substitute ATTESSA for A-LSD in your case.
But, if perchance your A-LSD was not functioning properly because of this failed sensor, then it is a prime opportunity to fling the smelly piece of crap in the bin (the whole A-LSD system) and replace with a diff that actually works properly.
Expand
thanks for that reply , what would be the test to understand if LSD was working / not working / functioning properly ??
haha yes, count the liquorice strips left afterwards. 2 strips good, 1 strip bad.
Sorry, I see your profile says r33 gtst, I had assumed gtr, didn't realise gtst with alsd had an attessa sensor too
Expand
The A-LSD controller modifies the slope of the LSD lock pressure vs TPS curve depending on how much lateral g you pull. The more lateral g you pull the harder it locks up: https://sci-hub.se/10.1016/0389-4304(94)90219-4
Seems kind of suboptimal to have an open diff any time you let off the throttle but someone at Nissan thought that was a good idea.
Expand
Reduces understeer. Remember, these are the same guys who came up with HICAS. It wasn't about making the best driver's car. It was about making something that sounded sporty and worked with very sub-optimal drivers.
  • Like 1
Not really fair, this was all mind blowing stuff back in 1987 or whenever the program started, and it was ahead of any other car of the day in multiple dimensions.
For sure, doesn't look great in 2022 though
HICAS didn't look great by the time the cars were only 10 years old. It was already the butt of jokes about cars trying to kill people. I had to "fix" my HICAS upon commencement of ownership in 1999. That's only 10 years from first R32 release, 6 years from manufacture of my car. Bastard thing was dangerous. Wasn't worn out, just had a (deranged) mind of its own at anything above 7/10ths. And that's ignoring the occasional outright panic mode where it liked to crank the rear wheels to full lock at 80km/h.
Just not enough processing power, algorithmic development and designed experience (in terms of what actions are actually required, and what actions are definitely not required) at that point in time to create a system that was actually going to do what was on the wish list.
Expand
Did you use the bar lock out method?? . I got a bar that wasn't installed when I bought the car . i don't think the HICAS is working as fluids are all gone .
Expand
Not initially, and also not ultimately. If the HICAS tie rod ends are in good condition, then the HICAS rack itself can serve exactly the same function as a lock bar. All that is required on an R32 to kill HICAS is to pull the smaller of the two loom plugs out the back of the HICAS CU. Stops working, no dash light (probably because the dash light wire is on that connector!!). The HICAS CU will lock the rack under a fault condition, meaning that it is "fail safe".....for a given definition of failsafe. I just happened to find a loophole (the small loom plug) that allowed me to exploit the design.
Later, I swapped the original HICAS rear subframe out for an A31 subframe with no HICAS. This is basically equivalent to fitting a complete HICAS eliminator kit (as opposed to just a lock bar). Lock bars keep the HICAS tie rods and they must be in good condition (ie the rod ends not worn). Eliminators can and should replace the original tie rods and the rod ends, replacing them with the sort of bushing that is used on the non-HICAS cars anyway. I just skipped all that aftermarket crap and went to an OEM Nissan solution to the same effect, that also happens to look completely factory, so that there are no obvious "steering system modifications", which would trigger raised eyebrows on a roadworthiness check. My car was going to have to go over the pits at Regency as part of the engine transplant that was happenign at the same time, and it sailed over without a word said. A lockbar or eliminator kit would possibly have got me in trouble.
Expand
There is no "fluid" iin R33 HICAS. This was the next generation of HICAS where the rack was electrically actuated.
As part of exploring G sensor and  A LSD i have found the leak in the the LSD pneumatic unit .
Seem like a repair has been tried before , un successfully !! Looks like a Pressure sensor of some kind .
Aside from binning the diff does anyone know what this part might be , as in genuine number and /or a non stock replacement part . thanks in advance .
PNazOiBVhccrlrZCsNiWG6W5Qn-1tTnpt1AHpH1e7j-RXxAjoo6zVjH4iqivUIl9kIEGODJiPTZl7ptUqzbZNL8oMa0djJWsUdmJE1FAdrGwv2shSVEeE_UsgWZFWLkN3zV3rSoMn19VTG8E_AuSYAgCPr5HXHjOAND2wiRwtXlPLZVndkcnQwcJB1JM_kkgV7vRZ3_6s_caYJMrLsAONiq7yU58lXKMa4b-mNHrYEtTBbH2v_ZKp29LEyRcPkSkpX9tlWrygqK_X88MRzKfAlUfOLmw0JcLA4rFQymVe2Lrqp3iCkrhrbBzWpQzsuZZnAN04TJWnkJ58XsTpqEIdfsWEC26DwtbzpAEwiG7bq_wovuT9UoEVQ07ps7EKVehRzlCqKlXiaqhr6IoerGMx-J4GqztSyc2HSNXJJFJGPzb5A2DjdrQ-IgDL04OkMUZ6EtmX7PUl2yd-mbP0KyniIYJEoDod3JyqM2s4tHKVviCmyq2IbH7v9W0kg6Gk4LY9FeVexvTjNngDqMINSuv_52iU18TQYPUNTHPRh9ZNpbob0O5ZGmiEyzGtifrDZgopj9x0F80C-YoGhVnioYRNFoW7JOJV1_9Atge85JeS-TemBZFPWJ-hPCulWfdwcQUGPgQYfBCJ0k8PNS6ItT7QFvrICfp2dHYznmxrSjWVwgoDRVU9vyOgHmZx1mLXtlBdYiXoGu4VFYiV3-W9-Tr6CS4mCFkNGDozJbeIerVgztJVSxsOzhHMWZpynFNgFuTksHk2EwS2-fZFNhWfq9IzvymweJCF2wpaFhpPmuf66TMvFeb5RM8KIoM6FilPwMoh8AHqlIYQMZhcxoxoQvC9DuoEa0c_MV8h3WmSCl4-z5rwre2VEQmBeNtO3aBK5lmj1tDoGfX3x6lAHG04iA67MUlzgRCyIHbIE3P50s5QNRJiDXMkg=w703-h937-no?authuser=0q4YJyw68VXn7wdqD8v77FZOuabW3gUPfWMFUJze2rGINb-24ty5K-PBHVlTTvj-UD0D6wuTKL8Zeh4pK7IpRJzUji9uWFjIZRTTpuzWdOaz97deUUzL3foSHVPsWkQXVQ5Rlmkxfjt2oBR0TS2yj9HPHupuJfAvhcIb2T8KNgdGpfn_jC0vRTEK9r6Qo6B6gMER9gU4Wgjbl9mQq_T2JG_pApfMTd9Rx-5CSYGqp1l_h96kK3NfooTjIwM9STQpTJq44ApEVCNaj4zFy8BTs3LYrAhd_7_oZdDEJ0eNqQTY1VSK1A_0bGpPq3wIgrGB2ZJNlgAAwCqHR29JnZVmLTWv-hahNMzK_w9IRTtdGii8qGlyrhkf7GZDUCf48zgLATBX5MigkNdyHuU_jsoAlYly3uIJn_vRuGBODoIhgW5iZ_Ut8CSYFQ9apBNlk7uMUn6rxGGs_5sgL87qRL-nWAFYflAlMrM9svTJPLuPfLUdWgfH4UZFTZluLcpbZlh49yoXRrqvGnswmVOJpmvPiLgcHoimw9QQUjTKGq9IUtZdQZYcbFB_iF7QvzcWAi2qcLUfMFdS_ZJtHVzPuswaalcod2buuILriMXxgqmno_hZbV2qmCXh_2UvN1OBCx2T99tFuRNHIp1W-tipNvO0ZSMJhWoOTgA8HaVzNYgL3_E-XF6x_dMjx5Hz_v5xTp_mn9OqkvJHgoyVyXWnzLjkpWnkWz_mz_K3GhgmQ-UcGy3KOBoo4aMHgSdIdAyzsfXRVNeeqeQehK-66kYL0W0XqiqQc5ER0OR163lsntjCaBQQ0FLpE6QaF9bQbUqs4R1vTekY10bW9hNUKxnTkIEzdg398YyV68Ghex5gy18-C0ygl8-DRBmhEAxYU3yDxroWg26973XY3yOg9eSfcBjBFsqgk59E9ar-lOCdDsZcbOQMMCVmdFw=w703-h937-no?authuser=0
Expand
I don't think you can actually buy one separately as OEM. In theory you could get the whole unit sent off to Nismo for rebuild but the cost is hilarious: https://www.nismo.co.jp/heritage_parts/repair.html
If you are confident it's just the pressure switch and not anything else FPG sells the pressure switch by itself, not a direct fit but close enough: https://frenchysperformancegarage.com/products/fpg-nissan-gt-r-attessa-pressure-switch-replacement
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
