I just did a intake plenum job and replaced all the coolant lines. Now i am noticing that coolant is collecting on top of the intake manifold by the balance tube. I am puzzled by where this coolant could come from?? Does anyone know?
It was hard to get good pictures of it but it looks as if it's coming from the balance tube.
The red arrow is where its collecting
Edited by kevboost7
Pretty sure that coolant has come from the head coolant breather on the top right in your last pic, you can see the witness trail from it.
But, there is coolant in the intake manifold after the throttles, so depending what you changed it could also be one of those gaskets.
That last picture wasn't mine. I found it on google.
When you are referring to the intake manifold, are you referring to the balance tube right on top of it?
22 minutes ago, Duncan said:
Yes, the screw in the middle is the coolant bleed screw for the manifold, as it is higher than the radiator cap
wait, its not that... because that picture i posted wasn't a picture of it, i just found it on google. Is it possible the o-rings on the balance tube gone to crap?
The balance tube has coolant flowing through it. There are a bunch of o-rings that seal up the balance tube to the intake manifold. That can be one leak path. The other is the intake manifold up against the cylinder head. The throttles themselves don't get coolant flow to my knowledge but the intake manifold does. I recommend undoing the harness on the balance tube so you can get a better look at where the leak is coming from. Certainly a lot easier than getting eyes on the back of the intake manifold up against the firewall.
1 hour ago, GTSBoy said:
USB/WIFI inspection camera is only $30 on eBay. Just sayin'.
Those things are so low res as to be useless for spotting leaks unless it's super obvious. It really shouldn't be that hard to figure out the source of the leak. If the actual photo wasn't out of focus it would be pretty easy to see what's going on.
Not true. I'm not talking about those shitty all-in-one borescope things. I'm talking the ones that connect to an app on your phone. Quite good resolution. I use one regularly for inspecting the insides of industrial equipment. They are cheap, cheerful and I wouldn't be without one.
  • Like 2
Did you buy yours on ebay? Would you be able to link to the listing? Or at least the brand name they use for it. Thanks!
I had a quick look at finding just a non-shit camera at some point but going through the listings I found it hard to figure out whether I was looking at junk or something that's actually worth buying.
Would love to get a link, I keep using a chinesium harbor freight one and the image is horrifyingly blurry. It was useful for getting that paper towel out of my intake manifold but anything smaller than that and I had a hard time spotting anything.
Yes, eBay. Have had for a few years now, so the listings are not the same. I would suggest that most of these would be sufficiently close to the same thing that it wouldn't really matter.
https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=wifi+inspection+camera&_sacat=0
This one though, appears to be the same one I bought. I got one with a 2m cable, for compactness, because I carry it all around the world, but you can also get 1, 5 & 10m lengths. The longer lengths are not useful without taping it onto a stick if you need rigidity, and not steerable if you need to control it inside something, but still might be desireable for some. But 2m seems like the best option to me. I only paid ~$25 for the 2m back then. Looks like prices have, understandably, crept up since. I did "guess" quite well at $30 in my first post above though!
https://www.ebay.com.au/itm/363941200352?hash=item54bc9601e0:g:zqAAAOSwDUpi5TcL&amdata=enc%3AAQAHAAAAsInvOgSeC%2FpzavmgsvfJjNJTNrIf1ZyW7EYIwG76Nfg3x4%2BKp1rYUt%2B3pIBPmvkZjm4OmBvjomQngDzTt1odFGXBk5JMHPSKgfEbZnU7vgu19BjYqHS9PlctnhLwkn3XyePoBjvVT5I2BoAuocIUB7isNXWIhTuW2161XJ5uO%2Bz6KujjZUBq%2Bh4%2B2G7DOke3o13w56ZqkZFPpF071P0p6sGQbfRo4ghPHK06Lf7Sw2Zo|tkp%3ABk9SR4y0qOj9YA
  • Like 2
  • Thanks 1
Thanks @GTSBoy, much appreciated! Just put in an order for the one you mentioned. To me they all look the same. It can't be any worse than trying to point the phone camera at things.
Should be here within a week or so. Can report back then on what it's like @joshuaho96.
Let says that the o-rings went bad on the balance tube, would i be able to replace those without having to remove the intake plenum?
Dear god i hope i dont have to do that job again. I just did it a week ago...
Yeah not fun...but back to an earlier question, exactly what did you have apart. It is highly unlikely something you didn't touch started leaking straight after you did something.
Did you just remove plenum, then throttles as a single unit, then intake manifold as a single unit? Or did you partially disassemble one or more of them?
I should add, a radiator pressure test kit might be worthwhile if you are having trouble finding the leak. It pressurises the system from the radiator cap and  will make a leak location obvious
You can try but I have a feeling the answer is maybe not. The hoses and pipes that hold it to the vacuum box under the plenum are a really tight fit.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
