What gauge setups are you guys running? Can't decide if i want to get multiple gauges fitted onto the dash or the A pillar vs getting the Haltech ic7 digital display. Curious to see what direction you guys went with. Post your pics!
https://www.sau.com.au/forums/topic/484142-gauge-setups/
I have run everything from centre mount Defi setup, a pillar mounted autometer, powertune digital display on the column.
I now use the realdash app on my head unit. Heaps cleaner, multiple custom display setups and connects to ecu over usb/CAN. Doesn't draw attention or standout.
Google is your friend for pics.
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7971486
What do you do with the car
Like Rob I've used gauges, loggers and dashes in the race and street cars, depends what you are looking for.
Of course, nothing beats Power FC hand controller for combination of engine display and ability to adjust tune if required
  • Haha 3
  • Confused 1
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7971487
2 hours ago, Murray_Calavera said:
Do you have an aftermarket ECU? If so I don't see how anyone would consider getting anything other then a dash that talks to the ECU over CAN in this day and age.
or can bus gauges when you don't want to swap out your factory dash like me.
  • Like 2
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7971520
  • 1 month later...
7 hours ago, Old man 32 GTR said:
Old setup with triple Defi gauges and new setup with double din stereo and motec C1212 dash
Dang... that motec dash is really nice 😍
how are you liking the double din setup? was it difficult to move the climate control to the top? i hear that some double din allows you to display the gauges on the screen
and what did you do with the OEM triple cluster?
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973349
7 hours ago, kevboost7 said:
Do you miss your old analog dash at all?
God no lol.
If you're not aware, the Haltech lets you switch between pre-set displays. So you can have one for track, street, road tuning, etc. It's a million times better then stock.
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973351
Street use?
This is Realdash in the stagea (horrible reflections but your get the idea) on an android head unit. Much easier to read than the pic implies
different screens and skins available, can display whatever you have in the ECU (makes more sense to attach a sender to the ECU than have a sender for a dedicated physical gauge)
In the Fuga I have a plug and play Greddy Informeter mounted next to the screen
Race car I use IQ3 for data logging and driver display and IC7 for driver/nav functions. I can't find any pics handy but the IQ3 is on the steering column partially obscuring the stock dash (which I kept for speedo, torque gauge and warning lights and the IC7 is mounted in front of the centre vents which are inop in the race car. Obviously the IQ3 has a logging function and analysis software which is super useful for race/rally
  • Like 1
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973353
Some thoughts on what I learned on this:
- Think twice before drilling into your dash or A-pillar to mount your gauges. When you change your mind and take them out again it looks like ass. I have holes in my A-pillar where a gauge used to live and I hate it. The Stagea for example has one huge trim piece that covers both A- and B-pillars. It can be purchased but it's meant to be an absolute bitch to remove and put back again so I haven't dared. I wouldn't be surprised if you would have to pay drug money to buy trim pieces for an older GTR.
- Go with something that can talk CAN bus. There are only limited spots to mount sensors. If it is on a gauge because it is important to monitor, it's important to the ECU as well for engine protection.
- Having gauges stuck all over the place can raise extra attention by police when being pulled over.
That said, especially at night I like the look of analogue gauges. Here's a photo of mine with Defi din gauges. Looks pretty much OEM. Also the mutilated A-pillar. The wideband lives in the glovebox so it's normally hidden.
  • Like 1
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973370
Thanks for sharing your thoughts. I see the holes in the a-pillar, i know what you mean now. I was also worried about changing my mind and having holes around my dash and a-pillar.
Edited by kevboost7
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973780
On 12/10/2022 at 4:40 PM, Duncan said:
Street use?
How do you connect the real dash app to your ECU?
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973781
Meanwhile I've pulled out all the gauges from my car.
Less distractions, let the ECU and multi level engine protection strategies do the hard work.
Will at some stage put in a small dash or just maybe a CAN gauge.
  • Like 4
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973782
Connect a CAN analyser to the Link CAN and then connect that to the Android head unit by USB. I'll post up more details in the Stagea's thread when I get time over the break, a couple of things have been a pain
httpsstatics3.seeedstudio.comseeedfile20
https://www.seeedstudio.com/USB-CAN-Analyzer-p-2888.html
  • Like 1
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973784
This! all of this!! If you’ve got time to look at gauges then you’re not driving fast enough.
  • Like 2
https://www.sau.com.au/forums/topic/484142-gauge-setups/#findComment-7973787
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
