So I’ve had this car for about three months and it’s had a weird issue running since the day I bought it. Anytime I start it and it’s cold it’s runs good until it’s warmed up but after it’s warmed up and I drive it it starts to sputter when driving it almost seems like it has a misfire but it’s only noticeable when you are stopping and going I have no idea what it could be I looked at the spark plugs and they seem fine just a little worn but I’m starting to think it’s a cool pack issue I’ve gone through my vac lines and it seems like there is no leaks
https://www.sau.com.au/forums/topic/484143-issues-running-with-my-rb20deneo/
If this is happening as car gets warmer I'd be looking at the following:
Ignitor module
Coil packs
Fuel pump and associated electrical components.
Alternator output voltage
Also check that the motor is grounded back to the chassis and all grounds are clean.
Ignitor module
Coil packs
This is gonna sound dumb but what’s the igniter module
There is no igniter module. Robbo saw RB20 and glossed over the fact that it's a Neo, that doesn't have one. The old R32 era RB20s did. Your igniters are built into your coils.
All the advice to check ignition components is valid, however hot misfires from failing ignition components usually tend to show up under higher load, rather than just off idle. My question is, is it actually a misfire that you're experiencing, or more of a stumble to near stall? Dirty idle control valves can cause nasty transition from driving to stopping and vice versa. As can dirty TB.
  • Like 1
yep, saw rb20 and staright to r32.
Add these to the to do list:
Get a consult cable and check for error codes
Clean MAF
Clean IACV
@PranK is it time we do a Pinned generic fault to do check list thread?
I’ll get a video for you guys so you can hear what I hear
Wish I could help with advice but I haven't yet assembled my 20Neo. One thing I've read on the forums here especially about the Neos is a bad ground on the coolant temp sensor. During cold startup the ECU always runs in open loop until a set of parameters have been met and usually ignores the CTS. After awhile it switches to closed loop and starts following your CTS reading. However, if the ground is bad, it will be sending funky signals (if at all) and thus cause the motor to run poorly.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
