I have an RB25DET block, crankshaft, rods, forged pistons, flywheel and other bits for sale.
This is the original block from our series 2 R33 GTST. Some years ago we had low compression in a cylinder, and removed and stripped the engine – we had a broken ring land.
The block was taken to our machinist, who cleaned it, bored it .5mm (to 86.5mm), honed the bores, enlarged the oil return holes, decked it, and fitted oil restrictor & block-off as recommended by everyone. New welsh plugs were also fitted throughout.
The crankshaft was sent to a crankshaft specialist, who crack tested it (no drugs), drilled out the gallery plugs to clean it, grub-screwed the plugs, and linished it. The girdle and bolts are included.
The rods were fine, so nothing was done to them.
Because of the broken piston, we bought a set of CP 86.5mm forged pistons.
The engine was re-assembled with new bearings, gaskets, seals etc.
Not long after this the stock turbo shredded the impellor. We had the turbo rebuilt & hi-flowed by Hypergear, refitted it, and had it re-tuned.
Turns out something then went through the engine – we think bits of the old impellor – and scratched the bores. At this point we decided to go RB25/30, so sourced a bottom end and went through the whole process again.
The bits for sale are what is left over.
The block is in good condition, except for the scratched bores. I have no way to measure if they just need to be honed, or re-bored, but my gut feeling is they need a rebore. Block is a 75T casting.
The crankshaft is perfect, and as mentioned above has been grub-screwed.
Rods appear to be excellent, but again I have no way to be 100%. Almost new main & big-end bearings are included, and are in their original locations if the buyer wants to re-use them. This motor didn’t run for long at all.
Pistons will need to be assessed, but new rings will be needed at least. Pistons have some damage evident.
Also included, along with the block, crankshaft, girdle, girdle bolts, forged pistons, rods, main & big-end bearings, are the following items:
Harmonic balancer – original, with some cracks showing in the rubber
Flywheel including flywheel & clutch bolts
Water pump – as new RB25 water pump (we needed a different one on the RB30, one hole is in the wrong place)
Oil pickup
Rear main seal holder
Timing belt idler – again this was new, and wasn’t needed on the RB30 (uses 2 x tensioners instead)
Wastegate actuator – pretty sure this is an RB20 10psi actuator, but it was some time ago and I may be wrong. Actuator is stamped ASN79
Coilpack cover
I’d prefer to sell everything complete – looking for $600, which I think is a bargain.
I’d also (much) prefer local pickup – parts are located in Adelaide’s north-eastern area.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
