Thanks for having me!
New to the forum- long-term Z32 owner, new R32 GT-R owner from Brisbane, Australia.
Currently searching for info regarding wheel/tyre fitment- purchased this old girl on Friday. She's clean for the price, but the wheel/tyre width is a huge problem.
18x10.5 +15 Enkei RPF1's
285/35R18 tyres
Wheels are in great condition, it'd be a real shame to replace them but they are causing major issues in the front of the car- they've worn through the inner guard liners and physically restrict the steering (can't turn to full-lock).
If you've run this size wheel, I want to hear from you! Can it be done with a smaller radius tyre, or am I up for replacing both the wheels and the tyres?
Cheers 🍻
  • Like 2
https://www.sau.com.au/forums/topic/484179-new-gt-r-owner-%F0%9F%91%8C/
Hi Sam, congrats on the purchase.
Unfortunately 18x10.5 don't fit properly on the front. You might get away with removing the guard liners and using undersized "stretched" tyres.
18x10 +15 to + 22 fit OK
The Enkies are not particularly strong wheels and you will find examples of broken ones as well. These days a GTR deserves quality wheels that fit properly.
  • Like 1
  • Thanks 1
Thanks so much @Duncan!
Was in two minds about trying a smaller diameter tyre VS new wheels/tyres, that advice confirms it 👌
16 hours ago, niZmO_Man said:
18x10 +20 is the max i'd go (it's what I'm running)
285/30 looks good and fits better than 275/35
285/35 is too big IMO
Thank you @niZmO_Man, appreciate your advice.
At the size you're running, do you have any issues with the tyre contacting the inner guard liners? Assuming you haven't had to roll or otherwise modify the front guards?
Guards rolled. My car is fairly low and it does occasionally rub on the front liner on full compression, although not as bad as 275/35. I also run like -2deg camber and about 6deg castor.
  • Like 1
21 minutes ago, Shoota_77 said:
I had one, terrible car!  The CVT felt like it was operated by the loosest rubber band ever made….
I second this! We're in the process of getting it ready for sale lol. Don't get me wrong, they're nice enough to drive when they're working. I’ve just had too many issues with Subaru's to want to add another to the list 😂
  • Haha 1
Update: picked up a set of 4x R32 GT-R wheels locally. Long-term, but not permanent solution. Tyres on them are shot and require replacing, but have MT's fitted to 2 of them (255/50R16).
Will be test fitting to check tyre size as I'm eyeing off a new set of Toyo Proxes R888R's (245/45R16). Once I pick up a new set of wheels for her, these will be stored for track use.
Edited by Sam_AusBNR32
Adding info
  • Like 1
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
