55 minutes ago, GTSBoy said:
245 is a little bit too wide for 8" wide wheels. 235/45 much better. If you do go 245, then 40 profile a better idea.
Thanks @GTSBoyย
The OE wheels currently have Mickey Thompson ET Street Series fitted, in a 255/50R16.
245/45R16 sizing was a calculated decision; (I understand this is much larger than the factory tyres), slightly smaller rolling diameter than the MT's, shaves the tyre width as fitted from the MT's @ 10.04" down to a more respectable 9.65".ย ย
Tyre dimension chart below for reference.
As per your advice, I'll look further into it before ordering ๐Ÿ™‚ย
You can run fat drag radials because they are not about turning corners. But for decent street/circuit driving, too much width leads to baggy sidewalls which is not nice for cornering performance. You have to rein in your (completely understandable) desire for more rubber on the road to avoid the compromises you have to make elsewhere.
Every time I go to buy tyres I um and ahh about putting 245s on my 8" wide wheels, and eventually punch myself in the face and stay with the 235s. As yours is a GTR, wider tyres are eminently possible - you just need 9.5 or 10" wheels.
  • Thanks 1
๐Ÿ˜‚๐Ÿ˜‚ Loud and clear; I appreciate the proverbial punch in the face too lol.ย
Even on the 9.5" and 10" wheels like I have on the 32 GTRs the above is true. 275 or 285 does not fit on car or corner as well as 255 or 265 with these widths.
  • Like 1
  • Thanks 1
On 08/11/2022 at 9:31 PM, Shoota_77 said:
I had one, terrible car! ย The CVT felt like it was operated by the loosest rubber band ever madeโ€ฆ. ย
Mine was a GT wagooon manual. Floppy shifter but otherwise ran fine. I was rather lucky as I had zero issues with it. I found it quite a luxurious ride.
As for tyres, my general rule of thumb is:
7.0" = 215
7.5" = 225
8.0" = 235
8.5" = 245
9.0" = 255
9.5" = 265
10.0" = 275
But I did put 265/35 on R34 GT-R (18x9) wheels though
  • Thanks 1
7.0" = 215
7.5" = 225
8.0" = 235
8.5" = 245
9.0" = 255
9.5" = 265
10.0" = 275
This assumes all tyres are measured equal, which they are definitely not. In real world an AD08R in 265 is wider than their own Advan v105 in 275 for example. RS4 265 is about the same as an AD08R 255, so this fact alone really complicates things. It'sย  taken me about 15+ years to get my head around this from trial and error,ย  which always makes me cautious on using a tyre I'd never tried before.
  • Like 2
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.ย  That's when you get into the big bucks.ย  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.ย  The guy that does them manipulates the tune on the vehicle to make sure it passes.ย  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.ย  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.ย  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.ย  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testingย  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificateย
ร—
ร—
