56 minutes ago, Dose Pipe Sutututu said:
it's not a 2nd regulator, it's a fuel pulsation damper
And why would you want to make it a returnless system?
would it be able to be removed cuz it hits the intake mani and cant bolt down I have a FFI
You cannot remove the reg. You need a reg. If you remove it, you will need too remote mount it or a replacement.
You cannot remove the pulsation dampener. It wont run nicely without it. If you remove it, you will need to remote mount it (and it wont work as well as it should when remote mounted.
Revert FFP to stock, or go full aftermarket rail and reg. No halfway measures.
Probably buy the radium rail then cuz it’s not ffp it’s a whole ffi from speedtekauto
5 minutes ago, Prof_Finesser said:
i already have the mani
So it's a  Freddy. Are you sure it fits? These things (the Freddies) kinda have a history of sucking. Literally. Through the flange gaps.
  • Like 1
17 minutes ago, Prof_Finesser said:
Its a real mani and it fits really well Im going to just buy the radium rail and damper
Its a copy of another companies......
Say bye to low/mid range torque.
Plazmaman plenum and DBW is way to go. Their rail bolts on too with no issues.
  • Like 1
I run radium everything, rail, reg, 2 x fuel pulse dampers in the rail... I can confirm the quality is on point!
Edited by Murray_Calavera
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
