Hi SAU,
Having boost related issue with my BCNR33. Car is making no boost! Triple gauge is registering vacuum, needle moves from negative to 0kg/cm2. Car drives normally, no sputtering or misfiring. AFRs also reading normal. Acceleration feels normal up until 3500rpm or so where you can begin to feel the lack of grunt. No woosh sounds either, just the sound of the HKS mushrooms sucking air.
Just a little background on the car: HKS2530s, 2.8, E85, VIPEC V88, ~20psi max boost, 4in Exhaust.
Recently had front turbo oil feed replaced by mechanic due to the old one being cracked. Got car back from them on a Sat and it was boosting fine but felt a little underpowered. Didn't drive car again till Wed. This is when is stopped boosting all together. Didn't hear any bang/pop, didn't notice any smoke either. Currently waiting to hear back from mechanic.
In the mean time have inspected piping on both hot and cold sides (also checked FMIC piping behind indicator grilles) for potential boost leak, however wasn't able to find anything loose or hissing.
Doing a little research on these forums leads me to believe that it could be a blown turbo or a blocked/malfunctioning CAT. All of the posts regarding no boost and blown turbos usually are owners with ceramic wheel turbos, which mine aren't.
With my limited mechanical knowledge and tools I've taken as much piping as I can to check the turbos. The front turbo looks okay? It spins freely and has no shaft play.
Don't have the tools to check the rear turbo as I can't get that elbow looking thing off to inspect the wheel. I'm yet to inspect the CAT.
Question: If one turbos blown will I be getting half the amount of full boost or just no boost at all?
Question: What are the chances of the CAT causing the absence of boost? I assume it would have been the ceramic wheels dropping into them. But again, I'm certain I don't have ceramic wheels.
Question: What do you reckon is causing no boost?
Appreciate any and all help!
https://www.sau.com.au/forums/topic/484192-r33-gtr-lack-of-power-boost-issue/
Blocked cat it'll still make boost, just very very lazily and probably not peak but it'll still go positive pressure.
No boost
Broken turbo with no turbine wheel or massive split in intercooler piping. Drop your exhaust in front of cat and check it out.
  • Like 1
  • Thanks 1
No boost
Thanks for the reply Ben!
Managed to get a pair of small hands to check if the rear turbo wheel was there and functioning, and much the like the front, it's still there and spinning.
Don't have the tools and equipment to drop exhaust atm. So as per your advice I proceeded to check intercooling piping for splits, and lo and behold:
Gonna get a new one, fit it and test if that solves it!
"well, there's your problem"!
pretty sure that counts as a major boost leak. You need to stay off boost until it is fixed, because your turbos will be making eleventy boost at the turbos
  • Like 1
Yep! Time to find a replacement! Any suggestions? Waiting for responses from Kudos Motorsports and Vega Autosports. Part number 14463PF / 1446324U00 if you wanna help look hahaha.
Are there any non OEM alternatives? Ex-Japan is looking like its gonna cost north of $300.
8 hours ago, RB335 said:
Check your engine mounts are good, too much movement may not be good for hoses.
Was just about to ask this. Thanks mate will have a look! Besides age, what else could have caused this tear?
It's not clear which one you are after from the pic, but aftermarket silicone will last better
https://justjap.com/products/cooling-pro-silicone-intercooler-hose-kit-nissan-gtr-stagea-260rs-rb26dett
  • Like 1
Yeah that kit should do it. Cheers mate!
Its this one:
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
