370gt coupe Retrofitting
Hi Guys, i'm in love with my 370gt, my first car here in Australia and i'm thinking to get a new look for the interior. My question is if someone knows if newer parts from nissan would fit our babes.. for now i'm thinking on post 2018 Qasqai steering wheel and shift knobs, they look fresh and clean. What are your thoughts on this kind of mods?
Will they fit?
 cheers!
  • Like 1
You might be the first to try.
If you can do a test swap with someone that has a Qasqai before you commit.
The plugs for the steering wheel buttons might be the same, but if not you can always rewire
  • Like 1
Airbag compatibility is another consideration. Not to mention whether the spline is even the same, shape of steering column shroud vs. shape of back side of steering wheel (and therefore how poxy it might or might not look from the side/top view), etc etc.
  • Like 1
Do you know if is there any way to check this? like technical specs or something like this? the plug seem to be the same, but not sure about the voltage, resistance, or anything else that could involve this
You'd be well advised to work from factory service manuals.
What do you mean "Just checked here"? Do you mean you looked around on SAU for FSMs? Or do you men you asked here? Because, you'll probably need to put more effort in than that to obtain both FSMs. Theres' no way that anyone on SAU gives 2 shits about Qashqais, so won't have a manual. And, you are probably the 1st person ever to want to swap a wheel from a more modern Renault Nissan into a V series Skyline.
I looked on infiniti g37 service manual, and only show info about the replacement procedure, there's no technical details on it.
Yeah, probably XD.. i prefer this newer models much more than those carbon fiber aftermarket ones, and they would be waaay cheaper also, so gain/gain if it works
well, i quit.. if it was just a project car or track, i would probably do it, but is my daily one.. so i will get one of these and it's fine:
https://www.steeringcover.com/mewant-hand-stitch-sewing-black-leather-suede-carbon-fiber-car-steering-wheel-cover-for-infiniti-g25-g35-g37-2007-2013-ex35-ex37-2008-2013-q40-q60-2014-2015-qx50-2014-2018.html
But thanks for help @GTSBoy
Edited by marcus1070
o0ooo.. these sew on's are a huge commitment. Get the video before you buy, and check around on how long it takes for a first timer, not a professional. I think I saw something on youtube which made me hesitant to go down that path.
Yeah, i seen it. It require some patience to do. But i already installed my niftycity module,, so with my car i have it xD.. but i guess it's necessary to remove the steering wheel from the car, even they saying that is not required, doing that inside the car would be a pain in the axx.
Please report back with how you go! They look great in the photos. But then I saw the list of ingredients and went "yeah nah, I would completely stuff that up".
Quote
What’s in the box
  • 1 Mewant steering wheel cover
  • 1 installation instruction
  • 1 double-side tape
  • 2 sew thread
  • 1 thimble
  • 1 needle
  • 1 small blade
@Vee37, do you know of any professionals who do this? I like the idea of getting a well fitting cover instead of going for a whole new steering wheel.
  • Like 1
44 minutes ago, soviet_merlin said:
...snip...
No, the most obvious target, you would normally pay Motor Trimmers, who charge by the hour, it looks very labor intensive in time, and therefore I think it wouldn't be cheap.
One thing I have thought to look into is something like Air-Tasker. At least then you are not paying a skilled professional rate to perform simple repetitive monkey work.
Just did a quick search on YouTube, and found this vid. It took him 6hrs.
One thing I did notice before I fond the above vid, there are different patterns to stitch it to together, some would obviously take longer, but as expected, probably look better.
  • Like 1
  • Thanks 1
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
