G’day guys,
So the time has come for me to throw the mighty RB20 away after blowing it and I’ve managed to pick up a healthy rb25det s2 150-155 across all 6 and bores in perfect condition which surprised me, I’m aiming for hopefully the 400kw happy for more if I can and with the engine in good condition I don’t have the time to pull it apart to go forged. Specs I’m looking to run are the following:
  • Studs
  • 1.5mm Nitto gasket
  • Kelford 246-A2 vct Camshaft Set: 262/272 Degrees advertised duration, 9.30mm/9.35mm lift with there valve spring kit
  • Billet gears in oem oil pump
  • g30-770 with a 6boost and 45mm gate
  • plaz FFP with BPP Fuel Rail Kit inc Bosch 2000cc Injectors and FPR
  • Going to be powered by a haltech 2500
And probably missing some other stuff.
Is this a realistic and achievable power goal with This setup ? Any musts you can recommend?
Car will be for street duties tbh this is really what my budget allows but can always stretch if I have to.
Cheers,
https://www.sau.com.au/forums/topic/484221-400kw-rb25/
6 minutes ago, Murray_Calavera said:
If that's what the budget is, I'd think about not spending $ on cams and the inlet manifold, and instead spend the money on a Nitto oil pump and bigger/baffled sump.
The baffled sump was one I forgot to add and was going to go nitto but told billet gears would do the job if I didn’t want to to the collar.
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972735
I've used billet gears, I don't recommend it.
Just get a Nitto pump from the get go, a big sump, don't get Bosch 2000/2200cc (they're CNG junk), convert to DBW.
Also 400kW rear wheel won't last too long with a R33 RB25DET motor, I would aim about 350kW for longevity.
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972738
Okay sweet, with the nitto pump I don’t have to do the crank collar ? don’t wanna take it apart tbh lol for longevity over 400kw would be looking at machining ? And forged ?
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972739
2 minutes ago, Dose Pipe Sutututu said:
If you want that kind of power and a working oiling system, that crank needs to come out and a collar put on
And at that point I’m probably best then doing the lot lol
thanks for the input man, I’ll call around and see if I can get away with doing the crank and Just keeping stock rods and pistons do new bearings and piston rings etc
Edited by 32pwwr
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972741
at that point you might as well just go for a basic rebuild, with H beams & pistons :)
What's the car's intent? street duties or drags/roll/circuit?
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972742
Street duties tbh man, just don’t got the budget for the machining and the wait time is ridiculous… I did consider if I could get away with balancing it all and slapping it in, not having to hone and bore it etc
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972743
My suggestion is to leave the motor as is, but at least get an extended sump. Aeroflow do decent ones with a 10AN return already welded on.
Fit ARP studs in, slap your turbo setup on and send it. Keep power in the 350kW region and it will live.
Once you open up Pandora's box, shit goes south.
  • Like 1
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972745
Awesome thanks bro, I did snap up a complete bottom end for peanuts I considered do a slow build on and later slap that in but that’s just an idea haha and 350rwkw-400kw would be a handful with a 32 gtst on the street
was making 270kw on the 20 and had an absolute blast with it so can see an extra 100kw being even more fun especially with more displacement
I was quoted a decent price with not much of a wait time for porting the head and doing a clean etc on it would it be worth it for what I’m looking for ?
Edited by 32pwwr
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972746
Don't bother with this unless you want over 500kW
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972747
Are you doing the engine build yourself? The cost to fit a crank collar is nothing in the grand scheme of things.
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972749
Pulling the engine apart yes, re-assembly will be done by and expert. just need to weight it up there’s no way of really doing it unless I pull it out and at that point I’m better off just doing a rebuild of the motor.
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972750
Put it back together yourself :)
  • Like 1
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972751
1 minute ago, 32pwwr said:
I was going to but with the money about to be spent don’t wanna blow it up, mechanic is awesome enough to let me watch and learn as he does it.
The money your spending on your mechanic to build one motor, you could use on educational material (say https://www.hpacademy.com/courses/learn-how-to-build-engines/) and tools to build X motors in the future.
I don't think you should be worried about 'blowing up' a motor from incorrect assembly. If everything is going well during assembly, turns over perfectly by hand, what is it that you are worried about?
I'm not saying you won't run into speed bumps along the way, but they should be apparent at the time and then you can address them as you encounter them.
The blowing up part is usually reserved for tuning issues lol. Speaking of which, are you going to tune it yourself?
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972753
23 hours ago, Dose Pipe Sutututu said:
and also a regular OEM mechanic shouldn't build performance engines...
One of my mates did that for his S15, it died after 3x track days. He learnt his lesson, albeit an expensive lesson.
My mate just works on rbs mainly 25-26, so rather pay him “mates rates” to do it in his off time hahha
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972776
I’m pretty good with the fabrication, painting and wiring. Get it how I like it but when trying to learn how to build a motor I just can’t get myself to by myself, I’d love to reason Ill do it along with him and mainly I’ll be doing it he’ll just guide me on it.
reason I learnt how to paint, fabricate and some basic wiring skills is Because my father and learnt step by step from him hahah
https://www.sau.com.au/forums/topic/484221-400kw-rb25/#findComment-7972777
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
