the awd/abs lights are illuminated.
Codes: (I believe I counted the lights correctly on the attesa unit-maybe shed light on how to accurately read the codes?)
61-FR and RR G sensor 1 and circuit
63-FR and RR G sensor 1 or 2 circuit
64-G sensor 1 power supply
I checked the G sensor under the center console, and it looks good.
pulled / cleaned all ABS sensors- no luck.
any help/better starting point would be awesome!
https://www.sau.com.au/forums/topic/484222-attesa-codes-r33-gtr/
Sounds like that G sensor isn't plugged in.
Per the diagrams GTSBoy scanned, all wiring to the G sensor comes from the ATTESSA computer under the rear parcel shelf in the boot,
pages CH-57 onwards in the 32 GTR manual cover trouble shooting the system, that is worth a read, but I'd start by removing the centre console and checking the G sensor is OK and plugged in correctly, and the wiring to it is not damaged. If it all looks OK you could check continuity between the G sensor and ATTESSA computer for those wires. In R32 it states 10A fuse #21 (4WAS) supplies power to that system
Did this issue happen suddenly or were you doing something prior?
