Hi.
I have been trying to figure out what wcu's that cross over the same harnes, but whatevwr i google i don't realy get a good answer.
I have truble with my rb25det s2 4wd auto car, and want to try to use a Manual ecu in it to se if it migth help with the problems im having, problem is that i have no idea what ecu that wil work with the engien.
And yes i do know that the gearbox wont shift on its own if i put a manual ecu in it,
https://www.sau.com.au/forums/topic/484229-ecu-crossover/
A manual Stagea won’t work properly as it will need to be from a NEO or an RB26. You could possibly use an R33 gtst ecu auto or manual. Either way AWD won’t work. But the auto one might work the gearbox. What issues are you trying to fix?
https://www.sau.com.au/forums/topic/484229-ecu-crossover/#findComment-7972846
6 minutes ago, GTSBoy said:
There's no commonality between 25Neo and 26 ECUs, so it won't want to be from a 26.
I have problems with the igniton timing and have had that for about 1-2 years, tryed to adjust multiple times, it showes as "corekt" and then it isent, car is slugish, slow, backfires, cherry red turbo after 10min drive.
Changed plugs, coils, maf, fule pump, fule filter, have alsow tried a different Oem ecu with no luck, had a sugestion to try a manual ecu and shift it myself to se if that would solve the problem.
Would go for a aftermarket ecu but nothing suports s2 auto
https://www.sau.com.au/forums/topic/484229-ecu-crossover/#findComment-7972850
Is it a series 2 rb25 or a series 2 Stagea?
https://www.sau.com.au/forums/topic/484229-ecu-crossover/#findComment-7972852
25 minutes ago, RBW49N said:
If you haven’t changed the CAS it could be that but it sounds like cam timing and as Ben says if the ecu has been changed it means it probably not the ecu
Cas has alsow been changed back and forth, timing belt have alsow been cheked a few times
Series 1 Stagea with a rb25det S2, or a s1.5 not sure, its a 1997 model and know ther was some stuff around there, do not have ign moduel on the coils.
40 minutes ago, Ben C34 said:
Also if another ecu had the same issue that says the ecu is fine.
The suggestion to use a manual ecu and shift yourself is laughable. It won't work. It will stay in 3rd gear.
have been chasing gremlins for about 2 years, at some point you have to try wird shit, a friend told me it could work, not that it would work, and should be abel to manualy change, i dont know before i have tryed, but if you say it wont work, sure
https://www.sau.com.au/forums/topic/484229-ecu-crossover/#findComment-7972856
How are you checking/ setting ignition  timing? There are a few ways to get it wrong that I can think of .
https://www.sau.com.au/forums/topic/484229-ecu-crossover/#findComment-7972859
Purple plug on idle switch and tps disconekted, 600rpm
Have a ignition wire betern coil and plug  to get most acuret reading
15° btdc = 4 mark, 1st is 0
Car is alsow stock exept for exhaust and a K&n open air filter
https://www.sau.com.au/forums/topic/484229-ecu-crossover/#findComment-7972860
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
