Hello everyone,
I currently have a 1995 r33 GTST that me and my father have restored over the past couple of years. We’ve gotten to the point where we are ready to make some good power out of our rb25det. The engine has around 130,000km.
Our aim is to make around the 300 - 350rwkw mark. I’d love to advice on what’s actually needed to make it to that figure, and what good parts we should run.
Thanks!!
https://www.sau.com.au/forums/topic/484240-building-a-rb25det-to-300-350rwkw/
There is a big difference between the work required for 250 and 400 kw (so, 300-350 kind of falls between those levels).
At 250 you just need a bigger turbo in the standard location, injectors to suit (probably safe to change fuel pump too), ECU with tune, bigger air flow meter, intercooler and exhaust. Likely price $5-10k
At 400kw you really need to change everything including forged internals, cams, radiator, exhaust manifold, potentially inlet manifold too. Probably MAP sensor conversion. Likely price $10-20k. Lots of people (but not everyone) break gearboxes at this level which is a whole other $10-20k rabbit hole.
So, for most people, budget is the best place to start, not a power target. If you have the open budget and want to shoot for 300-350, pick a turbo that hits that range, exhaust manifold to suit, any ECU that your tuner is comfortable with, intercooler and piping, dump/front/catback exhaust, injectors (bigger than you need), MAP sensor, apply $20k and see how you go. Once you have all that in place, higher power levels are just a turbo swap and tune away.
  • Like 1
8 hours ago, niZmO_Man said:
My advice is to spend some time searching around these forums. There is a dyno thread with mods listed.
^^^ lots of this and have a set budget as that will dictate what you can actually achieve
This would be the base stuff to start with
Hypergear highflow
Link plugin ecu
IDx1050
TI Automotive/Bosch 460L pump
plasmaman intercooler kit
Are you talking about engine only or all the parts required to make 350kw?
If you're talking engine only, my unopened engine makes that power easily on e85. So "required" parts, technically none? lol
But yeah if you want a list of everything required to make that power, as the others have said, best to do a search as there are a million ways to achieve that power level.
Might as well aim for 450kW, build a motor once and enjoy it.
Make 350kW on a 2 decade old motor with supposedly 130k km, it might last, it might not... Remove the uncertainty and just build it.
tbh...it is smart to 'build/mod' an RB with a long term future goal in mind.  So buy the parts and do the mods that will achieve that goal as you go...this may take 2 to 5 years, depending on cash flow etc
I guess I'm trying to say that if you have to drive around with a built motor and a standard turbo for a few months till you can afford the next step, then thats what you do.
  • Like 1
Yep, I agree with this. It's probably worth stating it as my previous post makes it seem like I believe the opposite.
So with my first motor, 100% stock, I got about 5 years out of it with street and track duties. I knew it wouldn't hold together forever with track use.
The plan always was, when the motor gives up, I'll quickly drop in another stock motor and rebuild the first one. Hopefully I'll have another 5 years now to finish my build lol. When that motor gives up I'll have a built motor ready to go.
The cycle will repeat again, built motor in, I'll start building the 2nd stock motor up and have a spare built motor ready to go.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
