r33 rust
i have a 1996 r33 gts-4 and had a roadworthy inspection the other day guy said he couldn’t pass it because of the rust near the rear k frame
any suggestions on what i can do to fix this other then “sell it” because gts-4s are hard to come by these daysC83CE66C-297C-459E-B9E3-CA7360DAF4C4.thumb.png.60ccdc8d2bb5c15a89df4d21abb89cd5.pngC959D4C7-16EA-459E-8756-43B26F6D00F4.thumb.png.2610d37e572cede58e52916a3a35dc15.png
left is passenger right is drivers side
Seeing as you've had to ask the question, it won't be any type of 'repair it yourself' answer.
I would start visiting workshops that focus on classic vehicle restorations/coach building/body building. I would be surprised if your average panel beating workshop would be interested in making a repair like this and even if they were, personally I wouldn't trust that them not to take shortcuts in their quest of maximising profits.
An example of the type of workshop I'm talking about is something like this -
https://www.automotivecraftsmen.com.au/
  • Like 1
  • Thanks 1
Ooooo damn, that's a tricky place to fix....  The section that the K-Frame is bolted to is a VERY structurally integral part of the car.  It's a massive job to strip all of  that apart to get to that panel.  Dozens of spot weld to drill out to remove all of the panels.
The other thing to consider is if there is that much rust there, most likely there is a lot of rust elsewhere too.....  If/when you get a quote, IT WILL NOT be the final amount as once they start drilling out spot welds more and more nastyness will be revelled.  Prepare yourself for that.
Good luck, I hope you can bring her back from the brink.
  • Like 1
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
