Hey folks,
I'm looking at getting a new clutch and was wondering what you recommend to use for all the bits beside the actual clutch. To refresh it all whilst it's open.
Do you get OEM? Or are there better aftermarket parts?
From discussion with my mechanic this is what I'm mainly looking for:
spigot bearing
clutch fork
clutch pivot ball
flywheel
flywheel bolts
release bearing
Striked through parts already come with the kit. This is for the pull type clutch on my 260awkw C34 Stagea. I'm getting a Nismo Super Coppermix Twin Plate. I like it to be somewhat future proof and it's my daily so driveability is important.
Lots of topics on clutches on the forums but I didn't see much on the little bits around it.
Thanks!
  On 03/12/2022 at 11:42 PM, BK said:
Fire your mechanic - Pull type clutch doesn't have a pivot ball.
Nothing to upgrade or change if sticking with a pull type.
Expand
Hah, I'm pretty confident my mechanic is fine and it's me being the dumbass. Thanks for confirming!
That also explains why the various Nismo and aftermarket bits just go on the push type clutches and older 2WD models.
  • Haha 1
One more question: do you have an opinion on original spigot bushing versus spigot needle bearing?
Via taarks the latter is described as "These needle bearings replace the stock brass spigot bush in the end of the crank that the gearbox input shaft goes into. The needle bearings last longer and put less stress on the gearbox and are also quieter."
Looks like in the forums people recommend the original bushing but no mention why.
Correct as above - I'm with these guys, stock spigot bush. I'd hate to have to pull a box just because a needle roller spigot decided to destroy itself. Needle roller is definitely a solution to problem that doesn't exist.
  • Like 1
  • Thanks 1
Thanks again for your help guys!
Everything is ordered. Ended up spending around $500 less than I was expecting. Glad I had a look around because rhdjapan had some promotion and sale going. Pretty chuffed with that.
Hello everyone,I have a problem on GTR R34
I purchased a spec SN26PT-2 clutch
Push type
I reassembled the engine and gearbox
Up to here everything ok
I start the vehicle,I press the clutch and try to engage the gears
At first they didn't engage
So I went back to purging
After that I went back to try and they fit
The problem arose when the clutch pedal was released
With any gear engaged, the vehicle does not move
It appears to be the neutral position
  On 06/12/2022 at 10:21 AM, Duncan said:
you didn't engage the pull fork correctly after the gearbox was reattached to the engine. pull gearboxes suck
Expand
Spot on - not to mention all the best clutches on the market are push type. The release bearing on a pull box is quite a shit thing isn't it 👎
Manolo mentioned that his clutch is push type, and you are both mentioning pull setups. What am I missing @Duncanand @BK ? Is it because R34 GTR came with pull from factory and it's converted?
Expand
He seems to be wrong as he mentioned the clutch is a Spec SN26PT-2, which is a pull type clutch. It's also harder to convert a Getrag in a 34R to push having a concentric slave cylinder and no factory push gearbox front cover available. On a 34 Getrag you can't just go and buy the factory parts below and convert to a push setup easily like on the other RB 5 speeds that come with pull front covers.
https://www.efisolutions.com.au/gearbox-conversion-kit-pull-to-push
The only way I'm aware you cam change a Getrag to push is with the specific OS giken pull to push kit which still uses the 34 concentric slave cylinder.
  • Thanks 1
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
