Hi new to the skyline and car scene. I just picked up an r33 with a rb25det engine. I need to recirculate the stock bov but I'm at a loss. I've done a fair bit of research on it but can't seem to get my head around it anyone brisbane based who could help for cash or know any shops that could fit me in quick. Cheers
https://www.sau.com.au/forums/topic/484253-bov-recirculation/
BOV is on the back of the crossover pipe. The outlet f that BOV needs to be piped down to the turbo inlet. This is shown in diagrams in the manual, but it's a pretty trivial route. The return pipe is about 1" and runs back under the crossover pipe above the exhaust manifold and then directed into the turbo inlet elbow, facing more towards the turbo than the AFM.
Or if you want to go down the expensive option to "fix" the issue, just bin the stock AFM, ECU, and install an aftermarket ECU, IAT & MAP (if you do not wish to use the internal one).
:D
Talk to me if you need ways to waste money, I'm good at helping with that. @BK also will help you spend money if you need LOL...
nek minnit, has a 2.8L stroker, 6266 to "fix" his BOV recirculation.
  • Haha 1
18 minutes ago, GTSBoy said:
Where's the Samsonas?
apologies, let me try again
nek minnit, has a 2.8L stroker, 6266, twin gates, twin scroll, DCT or Samsonas to "fix" his BOV recirculation.
That combo would actually make a fun car with a good powerband for the street, track, drags (if that's your kind of thing).
plumb into the turbo intake after the AFM. Plenty of places to get the parts around SE Qld- Trix parts, All Import wrecking or jdm garage. Its a 20min job and need a screwdriver and small sockets.
  • Like 1
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
